Question about Car Audio & Video
Remove stereo from 2002 nissan serena - Car Audio & Video
ilbdarned5
  • 19 Answers
SOURCE: how to repair nissan serena 2002 model qr20 engine
Things to check
Plugs;
Remove the spark plugs and read them, they should all have a dry tip and be clean from any carbon, oil or fuel.
Usually if burning fuel properly they will have a brown or whitish looking tint from burned carbon.
If any of the plugs look wet or black or dirty looking different from the others the problem is with that cylinder, change all the plugs and see if that helps, the next lease expensive thing is replacing the plug wires.If your fouling plugs ask your parts store for 1 number hotter plug ( heat range)
Plug Wires;
Open the hood at night with the engine running and see if you find any blue looking arcing around or in the wires, if so replace the wires.
Fuel Injectors
If all above looks good your fuel injectors might be dirty or one might not be working. You could try an injector cleaner mixed in with your gas
A rough idle comes from one or more cylinders not firing as hard as the others or not at all, there are so many causes for this so you have to troubleshoot with the lease expensive fix first.
Another thing is water in the gas, you can pour plain ole rubbing alcohol in your gas tank if you suspect water in your gas. alcohol mixes with the water and makes it burn instead of mis firing.
Valves
One more thing that can cause rough idle is your valves, this requires a compression check on each cylinder. If one cylinder has less compression than the rest remove the compression tester and squirt some engine oil in the cylinder then re test, if the compression increases it is bad rings or a bad cylinder bore, if not it is a valve problem.
Oil seals around the piston increasing the compression temporarily while testing but makes no difference in testing if the valves are leaking.
Good Luck,... troubleshooting and patience, or a good mechanic is the solution if you are working with neither
Posted on Mar 01, 2010
SOURCE: nissan serena problems
the problem is the rear wheels is kick out its a 1999
Posted on Jun 29, 2010
HansPP
  • 2510 Answers
SOURCE: 1997 Nissan Serena car
The stereo should only really come on when the key is at least in the ACC position. If it was like this before and now bypasses this position, I would say that the ACC contacts in the switch have failed in the closed position, There would not normally be a relay for that purpose. If it was like that before, the radio power has been taken from the wrong power supply and you need to find the ACC wire coming off the ignition switch.
Posted on Apr 01, 2011
Testimonial: "makes alot of sense going to give it a try thanks "
  • 747 Answers
SOURCE: nissan serena starting problem
you probably activated the security mode on the car call your nissan dealer
Posted on Aug 27, 2012
DIESELMUDDER
  • 2760 Answers
SOURCE: Where is my fuse for cigerate lighter in the Nissan Serena 2002 model, QR20DE engine
bottom of dash area left side by your leg, under cover painted to match dash color
Posted on Aug 09, 2016
Aug 08, 2016 | Nissan Cars & Trucks
Where is the fuel filter in the nissan c25 serena
You just go to the link I attached I'm sure you will get the solution of your problem
1991 2002 Nissan Serena Model 1057 23 Series Workshop Repair Service...
Feb 27, 2016 | Nissan Cars & Trucks
Wher the knock sensor is situated in a serena qr 20 engine
Hi Jeff,here's a link to the knock sensor,enlarge picture to see the sensor,then look at it to see how to remove,hope this helps.
Sep 25, 2013 | 2002 Nissan Altima
2007 nissan serena stereo
What do you need an English display on? Your Nissan or your copy of Rosetta Stone?
Apr 28, 2013 | Rosetta Stone Japanese Level 1 & 2 for...
Nissan serena starting problem
Aug 27, 2012 | 1990 Nissan Minivan
1997 Nissan Serena car stereo on but engine is not on, no keys in ignition
Apr 01, 2011 | Nissan Se R Cars & Trucks
I disconnected my car battery on my nissan serena and the car radio has locked and i have lost the code
if it has the original stereo then you can contact your dealer and they will help you, if its aftermarket then you must call the company that made the stereo.
Aug 30, 2010 | Car Audio & Video
Nissan serena problems
Jun 27, 2010 | Serena DataDirect Connect ODBC 1.0 for PC...
Differance between nissan largo and nissan serena engine
The Engines aren't the same for these two cars.
NISSAN SERENA RUNS EITHER: THE "SR" FAMILY ENGINE or THE "QR" FAMILY ENGINE. Find out which is yours.
NISSAN LARGO RUNS THE "KA" FAMILY ENGINE. IT IS THE SAME ENGINE FOUND INSIDE THE FAMOUS '240SX', I HOPE THIS HELPS YOU.
Oct 19, 2008 | 1995 Nissan Sentra
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
