Question about Orca Vacuums
Orca tilt a door stops as it opens - Orca Vacuums
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 15 Answers
Might have something blocking the movement !
Posted on May 05, 2014
The roller shutter does not stop while rolling up, noting it has a motor, what would be the problem?
The "up" limit switch is not working. there will be one to stop the door going up and another to stop it at the bottom.
They could be magnetic or a contact micro switch, check the door track and look for something at the top of the track with wires coming out and see if it lines up with something on the door when it is in the normal open position.Similar to a burglar alarm contact on a door or window. You could try putting a magnet next to it as the door is opening to see if it stops or if it is a mechanical switch try operating it manually (preferably with an insulated screwdriver)
Nov 08, 2016 | Vacuums
Chain came off tracks...repaired it and now it will not run full cycle...only goes a foot or so and then stops
if your talking about a garage door opener , pull the manual release , drop the door all the way,, with the handle still disengaged,, push the button to drop the door,, latch the handle,, try that , if that doesn't work, you need to adjust the chain so that reaches the stops at the correct time, here is a video on it,, Good Luck http://www.ehow.com/video_8739813_adjust-chain-garage-door-opener.html
Sep 11, 2011 | Vacuums
I have a 1/2hp master mechanic door opener. when I close the door it goes the full travel down and then opens back up. i checked the eyes and everything was lined up. do you have any suggestions?
Look at the setting for "fully closed". it sounds like yours is set for slightly than the actual opening....So, the door reaches that location, and it thinks it hit an obstruction, which causes the door to open....While you are there, reset the sensitivity settings.
What I would do is back off the closed position setting so that the door stops an inch or two off of the ground, then adjust until the door is in the correct closed position...
You are correct on the "eyes" (infrared sensors) being lined up, if they were not, the door would not close at all.
Mar 15, 2011 | Vacuums
How do you attach the upholstery tube to the main unit? thanks!
The larger fitting slides into the front of the dirty water tank. Remove the lid and either remove the duct, or lift it and tilt it forward on more recent models. The hose fitting goes in with the opening up, and the "V" shaped end down. After replacing the lid, push the round connector down onto it's fitting under the trap door on top of the nozzle, being sure it is fully snapped in place.
Feb 07, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a Chamberlain Liftmaster Professional 1/3 hp garage door opener. I'm unable to find the model number, but it was made in April 2004 and has an orange learn button. It has been working fine since...
Do you mean the numeric keypad is no longer controlling the garage door? If so, have you changed the battery for the keypad? Frequently, if the battery is low, the keypad will stop working when the door is closed but works to close an open door. On most Chamberlain garage door openers, this is a 9V battery. You may need a small Philips screw driver to open the battery compartment at the bottom of the keypad.
After changing the battery, try the learn code procedure again. I've found it easiest to have two people involved when programming the keypad to the garage door opener. One handles the Learn button and the other types in the desired code.
I hope this helps.
May 22, 2017 | Vacuums
Orca Twister - New filter needed
get the manual of the orca twister check it very well u will see contact of the company then contact them on how to get that
Apr 07, 2010 | Orca OC-910 Handheld Vacuum
I,m looking for parts. I've contacted the company to no avail. I need a new hose
You may have to check craigslist or E-bay. Or keep an eye open for newspaper ads, at thrift stores, and yard/garage/estate sales.
Oct 19, 2009 | Orca OC-950 Canister Vacuum
Loss os self propel and suction??
Your belts are worn out. These belts should be replaced once a year.
Sep 09, 2007 | Hoover U6630-900 WindTunnel Bagless...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
41 people viewed this question
Top Orca Vacuums Experts
JoeVacs
Are you an Orca Vacuum Expert? Answer questions, earn points and help others
