Question about Mitsubishi WD-52525 52" Rear Projection HDTV
WD-62525 works fine but has hazy picture!
Everything works fine, but picture looks like there is light leaking into projection area and is causing light haze to picture! I just repaired pcb connector problem, replaced lamp and blew out the dust! I know there is a foam piece which covers opening to mirrors, but it looks ok!
ISCABITTLE-TRY REMOVIG THE WHOLE FRONT SCREEN ASS'Y. AND CLEANING THE SMALL MIRROR INSIDE/BOTTOM YOU'LL SEE A HUGE DIFFERENCE-JOE TV
Posted on Nov 12, 2007
I have a mitsubishi wd-62525 the power light keeps blinking, and i can't get picture. i unpluge it than want 2min than it stop blinking and i can turn to tv on and get a picture than after 30-40mi
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green light
you can buy a DM or Power kits from tv repair. i changed the capacitors on both of mine but it has not fixed the problem. Same WD-62525 it may work for yours.
Dec 27, 2011 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced wd-62525 lamp, picture dim
Cleaning the mirrors will not increase the brightness much. I would double check the lamp setting in the Menu and also the setting of the picture and brightness settings. Many times these are adjustable independently for different inputs. Besides this, I would look at the Ballast and or the Power Supply to cause the problem. I would recommend a professional to look at it if it is not correctable from the Main Menu of the set.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsu #WD52327 DLP replaced bulb but hazy picture
Did you clean the small mirror. Dust will cover this mirror and give you a very hay picture. This is easy job and takes 15 minutes at the most. Someone posted detailed destructions on how to do this already if you look for it under WD52525 hazy picture.
May 27, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Best settings for moderate to low light viewing?
Using your remote, click the "video" button (mid area, Right hand side) and adjust the brightness, contrast, etc., to your liking. Only you know what you like. If your picture can be "plenty bright enough"...then just make the necessary adjusts to whatever looks best to you. If your picture is "very dim" no matter what the video settings are, you need a complete cleaning of all lens, mirrors, and screen...and possibly a new lamp.
Apr 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv brightness
I just bought an e 62525 on craigslist for $300 dollars. The guy had it in his garage because of a degraded picture... white out haze and virtually no black ... I surfed for similar issues most referring to the light engine. However; going back to basics. I removed the front panel assembly (approximately 16 screws including the center panel surrounding the card/rca ports in the front). The main mirror was spotless (in itself missleading) but the projection lense and the smaller mirror were frosted over with 3+ years of fine dust. I cleaned them with a simple cloth. I also noted that the foam insert surrounding the lense had gaps due to age which allowed excessive light sepage (the white out problem). I repositioned the foam as best I could. Then simply stuffed a black cloth over the foam but firmly arround the lense (keeping the foam intact as well). This blocked "all" light sepage. Bottom line is that I now have a picture quality that is flat out incredible! This is one bad mutha (shut yo mouth) tv. P.S. I'm just an average guy with an electric screw driver.
Nov 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Projection TV WD-62525
Could be quite a few things wrong. first I would do self test diagnosis and see what error you get, then check that area. It could be a bad Ballast or it could be Fuse F9a09 and the Light Engine. It also could be Caps C9a37 and C9a38. For additional info www.ctechnicians.com
Dec 10, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
233 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
