Question about Dishwashers
Door latch LG dish washer LD14AW3 - Dishwashers
5 Suggested Answers
sadguy
  • 88 Answers
SOURCE: wiring diagram on door latch
http://www.frigidaire.com/support/ResultsPage.asp?strModel=fdp635rfr3&User=
you will get on this web side all manual digram parts no
Posted on Aug 15, 2008
SOURCE: door won't latch on lg model LD2120wh
je cherche la télécommande de LG DR-4912V
Posted on Dec 24, 2009
  • 142 Answers
SOURCE: Washer MDBH940aww...the door is very hard to
Either someone bent the door by excessive weight on it while open (like a kid standing on it) or something is jammed in the sealing surface.
Posted on Jun 01, 2011
Daniel S
  • 4323 Answers
SOURCE: I have a Kenmore dish
Hi
The issue is with the door switch that is bad and should be replaced, or the relay for the door on the control is bad and should be replaced. Hope this helps...please post back with the model no. for further assistance.
Daniel
Posted on Jun 10, 2011
De error message on wash machine
For LG washers, the DE error indicates a problem with the door lock. If you just started the cycle and the error occurred, then the door couldn't lock properly. (The machine turns off and indicates the error so that the water won't flood your laundry area.) First check if there are any clothes between the door and the frame. If needed unplug the washer for 5 minutes. Then restart the machine try to open the door. If you pressed Pause, wait a minute or two. If the error occurs at the end of the cycle, it may not be unlocking properly.
The latch mechanism may have failed or the PTC sensor in the latch has failed. The entire latch would need to be replaced. Here's one: http://www.appliancepartspros.com/lg-door-lock-switch-6601er1004c-ap4441836.html . If the door locked failed with the door closed or the washer is under warranty, contact LG or a repair professional for service.
I hope this helps.
May 18, 2015 | LG WM2688H Front Load Washer
Why do no panel lights turn on when my Kenmore Model 587.1625 is latched and ready
The door latch in Kenmore and Kitchenaid isn't of the best design.The spring steel latching tab is needs to push down the black plastic slide mechanism when the door in closed. That slide pushes down on a micro switch which interrupts the cycle when you open the door when the dish washer is running. Take the latch assembly back out. You can insert two compression springs inside the slide on each side of the latch. They are approx 3/16 Dia x 3/4 to 1 inch long. In the hardware dept at Home Depot or Lowe's..The springs will push the slide down hard enough to activate the switch. Right now your dish washer thinks the door is open.
May 17, 2014 | Dishwashers
On my Amana Model # ADB1100AWW dish washer the soap door will not open during wash.
Possible Causes:
1) clogged door latch
2) door latch solenoid faulty
3) PCB Board
Oct 01, 2013 | Amana 24 in. ADB1500AWS Stainless Steel...
Washer MDBH940aww...the door is very hard to closed, it seems that you need to force the door close for the latch to lock.. The plastic door latch mounted on the dish washer is making contact wiith the...
Jun 01, 2011 | Maytag Dishwashers
Door seal on washer is leaking
The guys at LG recommend shimming the latch catch between the latch and frame to make the door close tighter. For true.
May 02, 2010 | LG WM-2277HW Front Load Washer
Have power but after selecting programe required light just flashes but does not start wash?
there is a switch in the latch on the door that won't let it accept a program, cause the sensor is telling it the door is open,if you can get at the switch, clean everything around latch and switch, make sure it's adjusted properly and all working smoothly, try again, if no work, replace switch, I've heard of this going the other way and people got all there dishs locked up in the dish washer because the safety latch failed,
Feb 01, 2010 | Dishwashers
I Have an LG front load washer machineit leaked water and I am getting error code LE
le is usuaslly a bad stator or hall sensor at the rear of the unit.the most common leak on lg washers is from the btm of the door.if you see water trickling from the btm of the door. then the door latch needs washers installed between the panel and the latch .also ive had one or two that cleaning out the pump solves the problem, manufacture reccommends unplugging unit and waiting 4-5 min and plug it in , it may reset the board it has a lot of boards and electrical parts inside .
Sep 19, 2009 | LG WD-1280FHD Front Load Washer
TROMM LG WM-2277HW
You may have a broken door latch switch that doesn't tell the computer that the door is actually closed.  Before you actually replace the latch switch, make sure the wire connectors are securely attached to the latch assembly.
Sep 14, 2008 | LG WM-2277HW Front Load Washer
Door Rattles
Get the rubber door boot loose, reach inside to where the door latch is and remove the 2 screws holding it in. Then put the screw back in but add a washer on the inside before you screw it back into the latch. Do this on both screws and it will set the latch further in the thickness of the washers. If one doesn't work you can try 2 but make sure the door can still lock or the unit won't run.
Feb 08, 2008 | LG WM-2277HW Front Load Washer
DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Oct 23, 2007 | LG WM-2032H Front Load Washer
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
Owen Barnes
