Question about JVC HD-56G886 56" Rear Projection HDTV
Im trying to connect my Hp Laptop to my JVC HD-56G886 TV by using the Digital in connection with HDMI cable. When I trun it to Digital In the screen turns green and after a minute it turns black sayin
Laptop recognizes the TV, but the TV isn't recognizing the Laptop
4 Suggested Answers
  • 87 Answers
SOURCE: JVC AV-48WP30, DVI to HDMI on Toshiba HD-A3 HD DVD
If a kit is available it will be expensive to buy and install. Most people can't see the difference between digital cables and component cables
Posted on Dec 23, 2007
SOURCE: JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Posted on Jan 25, 2009
SOURCE: My JVC HD-56G786 will not work with HDMI cable.
I had the same problem with my JVC projection tv. It would flash green, then go to regular picture then back to green flashes. Not sure if this is the solution you were looking for, but I was able to get a good crisp picture using composite cables instead of the HDMI cable.
Posted on Aug 30, 2009
I have a JVC HD-70FH97 hooked to my digital box, via HDMI cable, and connected to the TV HDMI input 1. I cant get my surround system to work - any ideas what im doing wrong?
Check your HDMI audio settings. It may be trying to send a signal that is incorrect. How is the wiring setup? cable box to stereo, then to Tv?
Sep 21, 2016 | JVC HD-70FH97 70 in. HDTV Television
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
JVC HD-56G886 tuner stopped working
My (unfortunate) guess would be the Tuner received a static discharge when you were changing the antennas... this time of the year is bad for static - if you're in a "Winter" climate.
Receivers have a very sensitive FET or MMIC amplifier right inside from the antenna connection to make it better for picking up distant stations.
However, this same "sensitive" amplifier is also prone to being destroyed by even a small static discharge... especially if the tuner had its power turned ON.
Sad to say, it's likely toasted... :-(
(I hope I'm wrong... but you have already tried all other possible solutions)
Jan 12, 2013 | JVC HD-56G886 56" Rear Projection HDTV
I had my Hp Pavillion dv9000 connected to my Jvc Hd-56g787 for a few months with an HDMI cable and evrything was fine. Now when I try to connect it gives me an invalid signal response and I changed...
What i suggest is try to download the driver of your video card from the manufacturers website. Also try to use a different HDMI cable and try also the laptop to other T.V. with HDMI connection and see if its having same error. If happend its doing the same thing try to reinstall Operating System and if that steps does not resolved the issue, call the manufacturer because the HDMI port is not working, its a hardware problem.
Feb 22, 2011 | JVC HD-56G787 Television
WHAT TYPE OF CABLE DO I NEED TO CONNECT HP NC6400 LAPTOP TO HD TV TO WATCH MOVIE ON TV FROM LAPTOP? VGA TO HDMI CABLE? THANKS
Hi.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
Hope it helps!
Feb 08, 2011 | HEWLETT-PACKARD HP NC6400 Core 2 DUO T5600...
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
JVC HD-56G886
Call your cable company, the lamp has nothing to do with the inputs, Maybe one of the connections is barely connected from moving the TV to replace the lamp.
May 06, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
HDMI input
The green screen is caused by light hitting the back of the tv. Either move the tv to a location where direct sunlight will not hit it or put up strong curtains. As for fixing the problem, do a search for JVC green screen reset on AVS Forum, its easy to do just dont have the info with me now. Keep in mind if direct sunlight hits the back of the tv it will do it again. I have put up some good curtians and ensure not to open them when watching the tv. Hope this helps. I am Hayward, have a nice day.
Aug 21, 2007 | JVC HD-56G886 56" Rear Projection HDTV
JVC HD-56G886 56" Rear Projection HDTV Logo
23 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
