Question about Blaupunkt IDC-A09 5-Disc CD Changer
Wiring of the plaupunk 5 disc multiple choice
Please how can i know which wires to connect to the speaker and to the car battery. the 5 disc changer hav 8 wires.
3 Suggested Answers
Eagleeyes
  • 199 Answers
SOURCE: Blaupunkt IDC A09
hi whats your email?
will email you.
mark
Posted on Jul 21, 2008
SOURCE: Blaupunkkt 5 disc changer
to take it out, you need two special toolsto insert in the four small holes on the sides. Since you probably don't have them, you can use four allen wrenches of the appropiate size. Just insert them and they will unlock the unit. (you might need something else to help you pull the unit very gently from one of the slots).
To reset the unit, I am not sure what do you meen by that. Just remember the unit has to be set up to work in the car's setup with the dealers interface module.
Posted on Sep 01, 2009
I have a JVC CH-X1100 CD changer in my truck. The sound is only coming out clearly on the driver side speakers....the passenger side speakers sound very low and distorted.
It is only a loose or broken wire to the left speakers. Try at the speaker itself first, and then at the radio. If both of these connections are tight, then check back along the wiring and check that the wiring TO THE RADIO LEFT SPEAKER is OK. If OK, you may have a break in the wire from the radio to the speaker.. It could even be an internal break that is hard to see. The easiest way would be to replace that wire.
Mar 24, 2011 | JVC CH-X1100 12-Disc CD Changer
Cd changer connections
Hi, On your Audiovox ACC56 10-Disc CD Changer with a Prestige P-165/P-185 FM Modulator, the wires: black - goes to the body (-) ground (as you correctly posted); Green/white - (with a small filter box) goes to the constant/always on 12V supply such as the + terminal of your battery Orange/White - should be connected to a switched power source such as the accessory terminal of your ignition switch or to the blue or yellow wire of your head unit or car stereo or whatever wire that will have 12V+ only when the head unit or car stereo is switched on. Hope this be of some help to you. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 21, 2007 | Audiovox ACC56 10-Disc CD Changer
I have a 6 cd changer is my Sebring. It was playing disc #2 and I decided to change to disc #5. An error appeared on screen and now I'm unable to get the Cd player out. I think the two disc got stuck as...
get two wires and hook one of them up to the radio on the power wire and ground it and press eject and rub yout stomache and pat your head and hop on one foot and try to bite your ear and it should be fixed
Jul 05, 2010 | Car Audio & Video
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
How to
Please follow the following instructions 1)Use a wiring harness equipped with an adapter plug for faster connection and installation.Disconnect the car battery while installing electronic equipment.
2) Make a note of the wire colors and connect the power supply wires to the DEH-45DH as follows:
Orange wire to the constant 12Volt
Yellow wire to the switched 12Volt
Black: ground wire
3) Connect these wires to control display functions on the DEH-45DH:
Attach the gray wire to the wire marked control panel illumination.
The brown wire connects to the dimmer.
4) Make the front speakers connections following this color scheme:
Left front positive (+) tan wire
Left front negative(-) Gray
The light green wire connects to the positive (+) terminal of the right front speaker.
Connect the dark green wire to the negative (-) terminal of the right front speaker.
5) Make these rear speaker connections:
Brown wire to the left rear positive (+) terminal
Yellow wire to the left rear negative (-) terminal
The dark blue wire attaches to the right rear positive (+) terminal
The light blue wire connects to the right rear negative (-) terminal
Hope this helps
Thanks
Smith.
Sep 09, 2009 | Car Audio & Video
Wiring hookup for 6 disc cd changer
battery would go to battery and acc. should go to the same wire that is marked acc. on the back of the radio. this is the accessories wire.
Jun 12, 2009 | Pioneer CDX-FM687 6-Disc CD Changer
Cd player in 1999 ford escort zx2 what color wires connect?
If you have a wiring harness, the wires are printed with the wires necessary.
Here is the wiring information for your car.
Please replay if there is any further help needed.
Constant 12V+ Blue/Red
Switched 12V+ Blue/Black
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Trigger n/a
Front Speakers 5 1/4" Doors
Left Front (+) Purple
Left Front (-) Blue/Orange
Right Front (+) Blue/White
Right Front (-) White
Rear Speakers 6" x 8" Rear Deck
Left Rear (+) White/Blue
Left Rear (-) Red/Blue
Right Rear (+) White/Green
Right Rear (-) Blue
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 09, 2009 | Sony CDX-C480 CD Changer
SPEAKER WIRE CONNECTORS
You need 5 Cord (wires) Connection to attache all speakers.
You can have all 5 cords in one package or each cord individually at Sony Accessories.
Please write model number DAV-FR1 in search box to get result on above web page.
Details of wires required.
182724411 1 BAG = 5 CORDS approx $43
179146811 CORD, CONNECTION approx $10.30
Nov 10, 2008 | Sony DAV-FC8 System
Blaupunkt IDC A09
will email you.
mark
Jul 19, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
Blaupunkt IDC-A09 5-Disc CD Changer Logo
104 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
