Question about Acer Computers & Internet
Wlan wires on acer 7736z
Where do they attach to the motherboard?
  • Acer Master
  • 3,320 Answers
After new hard drive how can i find my webcam
install webcam driver then only you can find your webcam
Mar 17, 2015 | Acer Genuine Ac Adapter Aspire 7736-6080...
My acer aspire notebook 7736Z-4412 won't turn on. I have tried taking out the battery and using the adapter but it still won't turn on?
yes boss pl remove ur battery n start only ac supply if ur laptop on or not if run ur battery defective or not run at ac ur laptop ac supply ac to dc converter circuit problem pl send my address solved n send u
May 26, 2014 | Acer Aspire One PC Notebook
Hello, I have an acer aspire 7736z-4088. The screen will come, totally blank but there is no sound of fans or harddrive trying to boot, after 15-20 seconds the screen will power down as well. I have tried...
If you have tested with an external monitor it sounds like you either have a dead video board (which would be integrated into the motherboard on that particular model) or the motherboard itself is bad. I would attempt re-seating the memory modules if they are easily accessible and try again, but it certainly does sound like you have a bad motherboard.
May 05, 2012 | Acer Computers & Internet
Laptop not coming. It shows that it is powering up nothing comes up pn the screen
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
hope this helps you
Aug 28, 2011 | SIB 320GB 2.5 Inchs SATA HDD Hard Disk...
I bought my acer aspire 7736z-4412 a little over yer ago. I don't do much on it other than check out facebook. It recently decided to shut down while I was online and now it won't start at all. I...
there are a few things that could cause this but here are the first two to look into before the last and worse case
your power adapter may have died. you need to have it checked. if it is ok then you porbably damaged the jack. if the jack is ok well then your motherboard has an issue. either the board is damaged or another problem exists.
Jun 29, 2011 | SIB 320GB 2.5 Inchs SATA HDD Hard Disk...
Manuels for Acer Aspire 7736Z-4448 Model No.
Hi
follow this link and hopefully you will find what you are looking for type in what you looking for
http://support.acer.com/
Nov 15, 2010 | Acer Computers & Internet
How do I enable the bluetooth settings on a acer aspire 7736z?
Hi there,According to the Acer Manual for your Laptop,The Fn+F3 keys Enable/Disable bluetooth.You can find out more about your laptops capabilities here...
http://support.acer.com/acerpanam/Manuals/acer/2009/UserGuides/QS_ACER_7736_7736Z_1_0_EN.pdf
Hope this helps,Good-Luck.
Aug 27, 2010 | Acer Aspire 4720 Notebook
Acer Aspire 7736z - 4088 I can no longer get the
It may be wiring problems in the articulation area of the camera. This was my problem and others had same problem. Try moving the camera to a different position a little at a time and then try connecting again. I tried downloading drivers, etc. not the problems with mine.
Jul 12, 2010 | Computers & Internet
How to change prorammable button on Acer Aspire 7736Z-4448
-Go to Windows Start
-Type in "Launch Manager"
-Choose whatever program you want to customize button to.
-If your program isn't listed there select "Add"
-You can add whatever program from your computer of type in a web address from there.
P.S. Acer doesn't list this anywhere, and they want to charge you for the info if you call them (so wrong of them).
Apr 01, 2010 | Acer Computers & Internet
How to change the programmable button on Acer aspire 7736Z
Go to your Start Menu --> Programs --> Task Manager. It is the Task Manager that actually handles the action of this button.
Mar 29, 2010 | Acer Computers & Internet
Computers & Internet Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
