50 inch hisense tv stuck on usb i have no remote and cant change back to av
SOURCE: LG plasma tv 42 and 50 inch
I have a 42inch LG plasma TV. It has a 4 inch wide stripe on the right side from the top to the bottom that is all different colors and goes from the topto the bottom.
Posted on Apr 12, 2007
Benimur
  • 6966 Answers
SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 24, 2007
SOURCE: tv is stuck on av channel
no-not the tv try buying another remote from the manufacturer and that will solve the problem
Posted on Aug 31, 2007
IrishDruid
  • 2712 Answers
SOURCE: hisense remote does not work with hisense tv
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: durabrand tv model Bh1304D stuck on av
CALL 1-877-337-3639 AND THEY W/TELL YOU TO BAD :-( THAN THEY WILL TELL YOU TO ORDER A REMOTE FROM 1-800-313-8495 OR 1-800-668-1067
Posted on Oct 07, 2008
How do i turn on smart tv mode with 1080p on hisense 55 inch without a remote
I think you will need a remote as i looked up the manual and every setting can only be changed by remote :( Maybe get a universal remote??
May 06, 2017 | Hisense Televison & Video
Measurements of hisence 50 inch 4K tv
From Best Buy's site I found this 50" 4k HiSense TV
http://www.bestbuy.com/site/hisense-50-class-49-5-diag--led-2160p-smart-4k-ultra-hd-tv-with-high-dynamic-range-black/4982500.p?skuId=4982500
With the following dimensions listed:
  • Product Height With Stand 27.7 inches
  • Product Depth With Stand 9.7 inches
  • Product Height Without Stand 25.6 inches
  • Product Depth Without Stand 3.3 inches
  • Product Weight With Stand 28.2 pounds
  • Product Weight Without Stand 27.6 pounds
  • Width 44.1 inches
Apr 03, 2017 | Televison & Video
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
CAN"T PLAY MOVIES FROM MY USB ON 32 inch HISENSE TV. What format should the movies be in? Presently they are in avi
i have a 32inch hisense led tv i watch movie using usb but it stop and back to the begining when the movie is over 2hours.. hope you can help me .
Mar 08, 2013 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
