Question about cabel adams Android Apps
1998 suzuki swift cino owners manual - cabel adams Android Apps
SOURCE: Don't have owner manual 4 suzuki - but dashboard light on
My 2006 Verona is doing this too. there is a hold button by the gear shift and evidently I had pushed it in and caused it.
Posted on Mar 04, 2009
SOURCE: suzuki swift 1.3 GLX
how do you know if the traction control is on on a Suzuki Verona 2004
Posted on Jan 10, 2010
  • 2002 Answers
SOURCE: where can i get a workshop manual for a suzuki swift 1300,1998
If you can't find one over there check out faxonautoliterature. They carry original manufacturer service manuals and they list 3 different ones for your car. I have used them before and found their service to be excellent. They are in California and I live in Eastern Canada and can get manuals in about 7-8 days. Hope this helps.
Posted on Jan 18, 2010
jimmybrown67
  • 835 Answers
SOURCE: how do i change the clutch on my 1998 1.3 suzuki
maybe chilton's will have a manual on this car. pull the transmission & front axle's to get to it . this is a real consumming job .
Posted on Dec 28, 2010
  • 280 Answers
SOURCE: My 1996 Suzuki Swift Cino is overheating.
Hello, if you are losing coolant as you say than the most probable place is through your head and into your exhaust system, it is highly likely you have a cracked head or a major head gasket leak. The only other place it can go is if you have a automatic vehicle with the cooler on the bottom of the radiator tank (crack between two tanks), it will go straight into your transmission, you can tell if the transmission oil is overfull and watery (thin and whitish).
Posted on Mar 07, 2011
Were can i get a free workshop manual for 1998 Suzuki swift cino in english for australia
join an Australian Forum, ever consider that<?
Our forum is USA and we don't have any books on your cars.
not only that, there is no PDF back in 1998. so some poor guy/gal
would have to scan it page by page front and back for a week.
no one has yet.. sorry, (hope im wrong but , i bet not !)
best place for real used book is on ebay (Australian, version)
login to alldata.com yet see if what you want to do matches yours?
login to suzuki pitstop plus and look
its just 4 bucks to look !
but the engine choice here, are less so may not match, same with wiring and wiring colors, and lighting, and other differences(laws)
https://suzukipitstopplus.com/Products/1123-1998-swift-service-manual.aspx
like first google hit?
http://www.suzuki-forums.com/australia/
https://www.facebook.com/suzukiswiftclubaustralia
ever google, and use Australia as part of the search?
our forum here X, is in California. and is not organized at all
and for sure country.
in fact, our forum forgets to even ask that. step 1. Sadly.
this one fact, makes most answers wrong, or at least 1/2
Feb 24, 2015 | 1998 Suzuki Swift
Were can i get a free workshop manual for 1997 - 1998 Suzuki swift cino
you are posted to a USA forum so answers on Cino are limited.
Cino smacks of Australia. join a suzuki forum there? and win?
what country, the book varies by country and engines.
some countries dont have your engine ,so is skipped.
Free now that is a tall order, and your time on google , is not going to be my time.... not ever.
we have 4 major on line virtrual FSM, an tnot one covers cino.
why not stated real year, not a range?
here is OUR swift, and will not be correct for yours.
Feb 23, 2015 | Suzuki Cars & Trucks
Can i fit a 1994 suzuki swift cino gearbox to a 1994 suzuki swift gti what the difference in gear and diff ratio will it be ok
You need to contact a Suzuki dealer and find out what the ratios are as a starting point and ten they can answer all your other questions also.
Dec 09, 2014 | Suzuki Cars & Trucks
Where do I fill the manual gearbox on my '97 Suzuki Swift cino ?
you should the filler / oil level plug on the side of the gear box about halfway up, it can be on either side,you will have to do this from under the vehicle this plug is both filler & oil level you will most likely need a special equipment to get the oil in, it is like a large syringe with a tube on the end of it (about12" long) you **** the oil with it & fill the gearbox that way until the oil runs out of the plug hole........hope this helps.......cheers.
Aug 11, 2011 | 1996 Suzuki Swift
Air intake Problem
It is called a warm up tube. It's purpose is to keep the CARB or Throttle plate area from icing up.
I have witnessed icing at 45 degrees (measured) ambient temprature. The low pressure surrounding the throttle plate(s) makes the area very cold.
If you do not have this tube, or the controls for it are not working, you get wierd stalling, or over rich conditions...Turn car off for few minutes (7-11 stop for example) and restart car...pretso, runs and idles perfect...
Mike
Nov 25, 2009 | 1998 Suzuki Swift
Cino 95. ignition coil resistances
IGNITION SYSTEM
1993 Swift
DOHC ....................... .72-.88 .............. 10,200-14,000
SOHC ...................... 1.13-1.38 ............. 11,500-15,500
Measured my 1994 Suzuki Swift primary was 1.3 ohms. The secondary is similar to the above
Oct 27, 2009 | 1994 Suzuki Swift
Car is stuck in second gear and wont go in reverse. it is a 1995 suzuki swift cino with a 5spd manual. Thoughts?
try rocking it while someone sits in it trying to pull out of second. This may give you enough play to get out of the stuck gear. Sounds like a linkage problem
Aug 19, 2009 | 1995 Suzuki Swift
Android Apps Logo
75 people viewed this question
Top cabel adams Apps Experts
Brett Duxbury
Brett Duxbury
Are you a cabel adams App Expert? Answer questions, earn points and help others
