Question about Acer Computers>Laptops Aspire 5610-2328 PC Notebook
I think my acer 5610 notebook has a virus. When I turn it on the Privacy center screen is up and I can't click out of it. What can I do?
  • 22 more comments
  • annabelduran Jun 20, 2009
    I am vista.
    Sorry to be a pest but how can I get on the internet? The "Privacy Center" screen will not close? Thanks
    Okay I tried to do the $59 purchase but I'm unable to get on the internet...Also how can I reboot my system without having to put in the administrator password (in Windows Vista)? I have forgotten it. I tried putting the reboot cd's but the computer doesn't read them.
    Ok I disabled all the startup programs using the MSCONFIG...but it rebooted and is still showing the same "Privacy Center" screen. What should I do now?
    Ok I'm returning to MSCONFIG and checking every box...
    ok now I'm in thru safe mode with networking and the Privacy screen is still on...
    I am unable to get online with the computer I'm trying to fix, but I have another computer...
    I downloaded it and put the flash drive in the laptop but it won't open anything up...it's weird
    okay so browse the registry editor list to find each one then delete it correct?
    What if they are not found....?
    ok I deleted the ones I could find what do I do now?
    can I restart my computer because its on the black screen?
    it doesn't bring up anything on the screen it's just a black screen.
    THe privacy center screen came up again...I guess I'm not going to be able to get rid of it...is there any way to surpass the administrator password?
    Yes i am trying the system restore and I am using administrator as a username put I don't know the password...any ideas how to bypass this?
    I know I wish I knew what I was doing wrong but thank you for your time and advice....
    okay I'll try that
    how about if the administrator username has been disabled?
    thanks for all your help hopefully it works
    I know thanks lol
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Were you able to solve the problem with the screen coming up?
  • Ben Wabnick
    Turn on your laptop and keep pressing F8 and it will bring you to a boot menu. Choose safe mode and let it boot up into safe mode. The privacy screen should not come up. Go thru the steps i mentioned to you about disabled the startup programs and then let the machine reboot into windows normally and see if the screen goes away.
  • Ben Wabnick
    click on the vista logo in the bottom left hand corner and then in the empty search box type in MSCONFIG and press enter. When the box comes up click on the startup tab and then everything that you see in there is everything that loads up when you boot up into windows. Click on the disable all button and then apply, then okay and then let the system reboot and see if the box comes back up. Let me know how it goes.
  • Ben Wabnick
    Are you running vista or xp?
  • 334 Answers
Yep sounds like a virus. What you need to do is go to
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
and download malwarebytes (click on the green arror and save to desktop). Restart your computer and push F8 repeatedly when it turns back on. A black screen will pop up, using the arror keys go to safe mode and click ok. Once its all booted up, go back to the malwarebytes file and install it, run a full sca (about an hour or so) then repair all findings.
Hopefully you'll be good to go. If you need anything else let me know.
Posted on Jun 20, 2009
  • 19 more comments
  • seth veloso Jun 20, 2009
    Ok you should still e able to do everything I posted. That version of malwarebytes is compatible in vista as well, you should be good to
    you should be able to access some sort of internet browser through the start button. If you click on the window, will it stay, It will probably take you to a site asking for $59 to fix your pc. just ignore all that and download the malwarebytes. If you still can't, try to reboot in safe mode Pressing F8 repeatedly at startup) and try safe mode with networking to get online. That privacy junk won't popup in safe mode.
    when you reboot, start pressing the F8 button as soon as the computer turns off. This will eventualy take you to a screen where you can choose to go into safe mode. Did you uncheck anything in MSCONFIG?
    not quite sure which person yo are following. what you need to do for now is go back into msconfig and check everybox. That will not disable the problem because it has rootkits that are difficult to ypass. You said you cannot get online? Is that starting with this "Privacy" problem. You need to get in to safe mode with networking and we'll start from there. Safe mode will disable this malware and let you concentrate on other things.
    wow that's weird, black screen and safe mode written in coeners? can you get online to download that program or do you have another computer?
    ok use the other computer and go to that link, save the file to a flash disk cd or something you can use in the other computer, then run it on the other computer, install and scan
    OK let's try the hard way. Press ctrl alt delete to open task manager, click on processes. Find these following processes, right click on them and end process. They may still pop up.
    tapinstall.exe
    openvpn.exe
    agent.exe
    pc.exe
    uninstall.exe
    protect[1].exe
    Step 2 click start=> run=> type in regedit hit enter
    In the registry find these following items and delete them. If you are unsure how to do this let me know. Make sure they are exactly the same as what you are looking a
    HKEY_CLASSES_ROOT\CLSID\{D032570A-5F63-4812-A094-87D007C23012}
    HKEY_CLASSES_ROOT\spbho.TIEBHO
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\
    Browser Helper Objects\{D032570A-5F63-4812-A094-87D007C23012}
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Privacy center
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run “agent.exe”
    HKEY_CURRENT_USER\software\microsoft\windows\currentversion\run agent.exe
    These are sites that you can block in your internet security if you have one. All this will be cleaned up and 100% taken care of when you run malwarebytes, but all this may halp you get control back so you can do that
    block following sites
    privacy-centr.org
    privacy-ceter.org
    privacy-centar.org
    privacy-center.org
    ok, that's to be expected. end those processes that I listed and the registry entries then try again.
    that is correct, the entries I have in the list are like addresses, find the first part first, then second and so on. You may need to kill the processes again after doing the registry.
    you could not find any? if missing a couple don't worry delete what you can
    go back and end those processes again then try to install that program off your flash drive and run it. Let me know if you get it installed
    nope, not yet
    ok try to reboot normally and see what happens
    have you tried the system restore?
    are you using administrator as a username
    I wish I knew where you were going wrong, if you could just get that program on there you'd be good to go
    your password is administrator. can't remember if the first a is a or A. if you get in there and no popup, get that program in there. If you can't, go to your other account, press ctrl, alt, delete and in that window log off then log on as a guest
    then log on as guest. at sign in, press ctrl, alt, delete twice, then type in guest with no password. see where that puts ya
    lol i hope it works too, I hate when I can't get it. I just took that off my friends pc, it wasn't this hard.
    here is a link that contains related files to manualy remove but if you could just click scan it would be so much easier
    http://www.2-spyware.com/remove-privacy-...
ASPIRE5610 Virus cleaning,camerapicture showing black&white,
Tell us more about the problem. What is the computer doing? What havee you installed? What is the camera picture? What is black and white on the screen?
Feb 01, 2013 | Acer Aspire 5610-2328 Notebook
ACER ASPIRE DOESNT STARTUP A SCREEN COMES UP SAYING "PRIVACY CENTER". IT ISASKING ME TO PAY 59.99 TO UPGRADE.
Virus! You need to scan your drive for viruses. Since it will not boot, you must pull the drive from the laptop and connect it to another computer using a USB cable that you can purchase from tigerdirect.com. After you connect the laptop drive to another computer, scan the laptop drive for viruses.
Dec 08, 2009 | Acer Aspire 1640Z Notebook
This morning my desktop photo ws still on my hp however all of the icons and tool bars were gone. I shut it down manually and restarted it about 10 minutes later. its comes up goes as far as the windows...
probably you might have turned off the show desktop icons for your desktop.
Right click on the desktop and then click on arrange icons by and the check the ---- show desktop icons option.
This should fix your problem
Nov 05, 2009 | Acer Aspire 5610 laptop vista combo with...
Acer orbicam not working
Might be hardware problem. So better send it to service center. Or you can try to take out the camera, remove the camera cable and plug it in back. I think this model got design issue for the camera.
Oct 06, 2009 | Acer Aspire 5610-4648 Notebook
Screen turns on when powered up then goes blank.
It sounds like you are having a backlight problem with your computer. The backlight is the part of the LCD assembly that lights up behind the LCD and shines through.
Sep 09, 2009 | Acer Aspire 5610-4491 Notebook
Virus scan
Yes can he install super anti spyware.
May 04, 2009 | Acer Aspire One PC Notebook
Pointer jumps around on screen when touching touch pad
hello, have you tryed adjusting the sensitivity of the touch pad to a less sensitive touch ?
Mar 31, 2009 | Acer Aspire 5610 Notebook
Acer aspire 4530 webcam isnt seeing me
i think your gonna need to uninstall came and reinstall or do a system restore back to factory default
Jan 16, 2009 | Acer Aspire 5610-4648 Notebook
My Acer Aspire 5630 shuts down by itself after about 10 minutes when I am on skype
I think the first thing you should check in the power save, Down by the clock, i know you can change how long your laptop is on to save power plugged in or on battery
Nov 30, 2008 | Acer Aspire 5610-4648 Notebook
Acer Computers>Laptops Aspire 5610-2328 PC Notebook Logo
162 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
