Question about Soundstream VIR-8310NRB Car Video Player
I am not geting sound out of my soundstream - Soundstream VIR-8310NRB Car Video Player
Soundstream tws.4. After installation, why is there no sound?
Check the gain or level settings
check the crossover settings from hp to lp or full
May 27, 2015 | Soundstream Car Audio & Video
I've had two soundstream rubicon 1.1600D amp's and they both worked for a while then the amp started to kick off and on. No fuses were blown, and the ground was fine. Any suggestions would be appreciated.
Sounds like a loose power connection? Check All connections, also make sure the impedance is correct 4ohm 8omh 16 ohm the speakers need to match the amplifiers output to work properly. ...
Feb 21, 2015 | Soundstream Car Audio & Video
Dvc wiring diagram
need the ohms of each coil and what the amp can handle in ohms
Dec 12, 2013 | Soundstream PCS-12 Car Subwoofer
Sound stream little wonder 62o. keeps tripping off for no reason its new only 3 weeks.spoken with other persons they have the same problem
IN MY OPINION I WOULDNT OWN A SOUNDSTREAM AMP NOT BY ANY MEANS KNOCKIN UR AMP BUT IVE NO GOOD LUCK W ANY SOUNDSTREAM AMP IVE EVER HAD
Feb 19, 2010 | Soundstream Tarantula Car Audio Amplifier
Soundstream XBP-10 Installation
Dude I sat down and made up a diagram for this and I cant get the site to let me upload it. If you can get a generic email quick from yahoo or something and get back to me I will email it to you.
Dec 22, 2009 | Soundstream Car Audio & Video
Soundstream rub 500-1 mono....
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Nov 21, 2008 | Soundstream RUB500-1 Car Audio Amplifier
Soundstream VIR-8310NRB Car Video Player Logo
26 people viewed this question
Top Soundstream Car Audio & Video Experts
Jerry Umali
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
