Question about Daewoo Dwc-F0520rle Air Conditioners
Daewoo parts for room aircon window type - Daewoo Dwc-F0520rle Air Conditioners
Which is better, a split type aircon or the regular one for home use?
It all depends on your requirement, However people prefer Split type as it less noisy, Can be installed at any place in the room. Easy to operate. Easy to maintain. Does not interfere with the layout in room. Wall mounted/floor resting.
May 14, 2011 | Heating & Cooling
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
MY AIRCON IS BUILDING UP SOME ICE
Sounds like it's low on charge, dirty coil. Is this a ductless unit or window?
Jul 26, 2009 | LG Heating & Cooling
My KOLIN window type remote control AIRCON is building up ICE
If you already had the coils and filter cleaned and the blower is OK, that only leaves the refrigerant charge.
You are probably low on refrigerant.
Jul 26, 2009 | Heating & Cooling
Doesn't quite fit into the wall sleeve. Can I remove the outer case of this a/c to get enough room to slide it all the way in?
I assume you have a window type aircon. if you can't slide the main unit into the shell then maybe the hole in the wall needs to be chipped. Although you can remove the outer case, it is not recommended because the internal parts would be exposed to the elements and would shorten the units life.
I hoep this helps.
Jun 03, 2009 | Heating & Cooling
Kolin window type aircon shuts off by itself
This may be due to the size of the room. The master bedroom may be smaller than the living room? The unit is therefore reaching setpoint temperature and cycling (shutting off)? Or it could also be a faulty thermostat.
Jan 23, 2009 | Heating & Cooling
Aircon works but blows hot air
I had the same problem (during Summer!!) - If you take the Fan/A.C/Temp Control panel off, you'll probably find the plastic bracket that the control cable mounts to, is broken. I just used 3 zip-ties to hold everything in place. 30 minutes work, & 50c parts!! No problems since.
Nov 12, 2008 | 2001 Daewoo Nubira
Daewoo Dwc-F0520rle Air Conditioners Logo
18 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Dan Webster
Dan Webster
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
