Question about Vizio L32 32 in. LCD HDTV
Vizio 32" hdtv model E32-AO
Power supply problem
SOURCE: Vizio L32 HDTV 10A won't turn on
I bought my 42" plasma Vizio 17 days ago and this problem just happened to me. We were watching and it just went off and it won't come back on. The tv clearly has power as the yellow light is on, but this tv simply won't come on. I called Walmart to verify I could return (I can) and they said they have two others that were returned sitting in back. I imagine this is going to force Vizio to do something soon, I can only imagine how many of these things are going to start failing in the years to come.
Posted on Aug 17, 2008
  • 4 Answers
SOURCE: code for Vizio tv
Unfortunately, those remotes only take a 3 digit code. I bought 2 new remotes, which do take 4 digit codes, but the code(s) for the Vizio do not work (or partially). I found that the 4 digit codes for the Goldstar and LG work better than those provided for the Vizio, but still not as good as the original Vizio remote.
Posted on Apr 01, 2009
SOURCE: VIZIO TV MODEL L37 HDTV CODES FOR THE REMOTE
I found the codes online at DishTV
505,627,775,758,756,885,864
Posted on Apr 11, 2009
  • 17 Answers
SOURCE: Power board for 32 in. Vizio
Yeah Shopjimmy has over 20,000 parts for vizio! I bet they would have a power supply for your tv. their website is www.shopjimmy.com
Posted on May 07, 2009
  • 6 Answers
SOURCE: vizio hdtv 32 inch wont come on.
More then likey you have a bad mainboard. Especially for the 32inch and below its usally the mainboard rather then the powerboard.
The tv parts are modular you can usally buy parts on ebay. I dont recomend soldering or anything like that, just a simple board swap will do.
Posted on Jul 19, 2009
My vizeo e320-ao has sound but no picture. is it the backlight
T'Con board fault. Check and replace it if you can. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 10, 2017 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Suddenly won't come on
Main power supply regulator board fault.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Jul 27, 2014 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Do you have to have a HD cable to hook up a PS3?
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Dec 30, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Can't download manual
http://store.vizio.com/documents/downloads/hdtv/E320iA0/UM_E320iA0.pdf
Check to make sure you have Adobe Acrobat X Reader or some other PDF reader installed before you attempt download and read this file.
Oct 16, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
When i go to turn my tv on,it turns on,with the vizio sign cming on the screen,then shuts off
You are likely to have a bad power supply particularly bulged capacitors on the power supply. The power supply can be traced by following the AC cord to it. Get the model number and do a search on Ebay and be sure to match the part numbers
May 20, 2011 | Vizio L32 32 in. LCD HDTV
POWERS UP BUT NO PICTURE
It can be bad backlight inverter board or the power supply is not supplying the 24vdc to the inverter board.
Oct 28, 2009 | Vizio VW32L 32 in. LCD HDTV
I have a Vizio hdtv 32'' lcd the power button is yellow, when I turn the tv on the button turns green but thats all that happens no pic or sound the model is Vizio L32HDTV 10A
I would guess the power supply went bad. The Vizio parts store sells the replacement for $82. Cheap fix for a decent TV.
Replacing it only requires a moderate mechanical skill. Removing the screws from the case is the hardest part. Remember to unplug the TV before you attempt this repair, or contact a local repair shop. They may only charge a small fee to install it for you.
Sep 13, 2009 | Vizio L32 32 in. LCD HDTV
Dec 17, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
23 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
