Question about Panasonic Office Equipment & Supplies
Printer a5 when i print a new doc page, the last printed doc appear. whats wrong?
SOURCE: only prints one page
I downloaded the "FULL PRINTING SYSTEM" but still cant get lights to stop flashing or paper jamming
Posted on Sep 19, 2008
  • 684 Answers
SOURCE: lexmark x4650 AIO, will only print first page of multiple pg doc
In this case what i would Request u to do is......... Goto Control Panel goto Printers folder......... There u will see the Lexmark Printer Icon........... Just right click on the Printer Icon and click on Properties......... Now click on Advanced and goto Print Processor......... Change it to Lexmark X1100 and NTEMF 1.0008........ Click on Apply click Ok now try to Print.......... Prints Fine............Issue Resolved........
Posted on Feb 05, 2009
gwbm
  • 353 Answers
SOURCE: will not print text only images
OK - here is all the help I can give to someone who won't respond to questions.
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Posted on Feb 27, 2009
  • 90 Answers
SOURCE: Printer will not print multiple copies
go to start menu, control panel, printers and faxes, right click your printer, click properties, click the advanced tab and make sure your printer is set to spool print documents.
Posted on May 29, 2009
SOURCE: Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Posted on Aug 17, 2009
Printing from my HP laptop all the printers will only print A5 size not fit to page A4. Have another computer and printers will print fit to page A$
Have you checked the printer settings when you get the print screen?
Most likely it is set up for A5. That or the page layout of the document is set for A5.
Feb 21, 2015 | HP Pavilion Computers & Internet
Oki - how to print booklet?
The paper you have inserted into the printer, and your page size settings have to match. You can't load A4 paper and tell it to print A5 size. This is why it is printing so small on the A4 paper. It assumes you need to trim it down to A5 size after printing.
Jul 15, 2012 | Office Equipment & Supplies
How to print A5 paper incannon 3300?
Go to printer and faxes, right click, printer preferances, page setup ,size , select A5 then paper source select casste 1. then click ok. Feed the paper through cassete 1. Print ready
Apr 03, 2011 | Canon LASER SHOT LBP 3300 Printer
HOW DO I GET MY C4500 PRINTER TO PRINT THE FIRST PAGE FIRST AND NOT LAST
When you select the doc to print a dialog box appears and there look for "PRINT RANGE", you will choose the pages that you want to print.
Oct 26, 2010 | HP Photosmart C4580 All-in-One InkJet...
I keep getting a test page before printing my doc or picture
To resolve test page prints every time issue, perform the steps provided in the below webpage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065136&cc=us&lc=en&dlc=en
Now, perform the steps below to change the settings from last to first page:
===== From the HP Solution Center software =====
1. Open the HP Solution center.
2. Click Settings--Print Settings --> Printer Settings
3. Click Advanced Tab.
4. Under layout option select the page order from "front to back".
5. Click OK and try printing.
From application
a) Select tools
b) Goto Options
In that select print tab
c) Check the Reverse Print order option.
d) Click Ok.
Apr 17, 2009 | HP DeskJet F380 All-In-One Printer
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
How do I reduce A4 printed notes to A5 size ?
Click on the File tab which is present in top left corner of the file, Click on Page Setup, a separate window appears, there on paper menu you can see a Size which is a drop down box. Drop down the size and select A5 and press ok. Now onwards it prints in A5 size. Later you can change it any size. Thank you........
Sep 13, 2008 | HP Office Equipment & Supplies
Printing 2 pages on landscape document
Usually if you see the page in the Publisher window is already landscape, it will go landscape in the Printpreview and also in the print out. I just try to imagine what is your problem.
If I am not mistaken, this is what you did:
You have two "small" pages (maybe A5??) and you want to print it in one page of A4. Of course the A4 should be landscape.
Publisher does not have the facility to set 2 pages A5 in one A4 like in Microsoft Word.
The easiest way is just create a new page with A4, then copy the 2 pages (or you called it flyers) and paste it in that A4 landscape page.
Publisher can do print 2 pages A5 in one sheet A4 but the arrangement is as booklet. You can see the choices in File --> Page Setup --> tab "Layout" --> scroll the Publication type.
I do print 2 pages A5 in one sheet with many variations using addition software named "Clickbook".
Let me know if I m wrong in interpret your problem.
Feb 10, 2008 | Adobe Photoshop 7.0 for PC
Last page of some docs won't print
Within the driver you can select what graphical language to use try a different one and see if that helps also check the paper size settings
hope this helps and please rate me
Cheers J
Aug 29, 2007 | HP LaserJet 1100 Printer
16 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
