Question about Samsung DLP HL-P5663W 56" TV
We have a Samsung DLP 69'' TV and as above, it keeps shutting off. We just replaced the lamp, which did not fix the problem. It will go on for a minute or two, then the TV shuts off and all three lights flash. We tried cleaning it, used compressed air, depressed the blue switch with tape, turned it on and off. Still just keeps shutting off and making a high pitched, rapid, soft beeping noise. Any ideas before I smash this $3000 peice of junk? Thanks.
  • bradk23 Jun 20, 2009
    People need to boycott Sansung! Buy SONY instead. Samsung knows about the defects but offers no remedy!
  • Michael Masters
    Michael Masters May 11, 2010
    do you here any clicks or the normal power surge when powering up?
Previous answers are wrong unfortunately. And I'm sorry you've spent the kind of money you have to fix it. Its actually a very basic, tiny, annoying cause. So much so you'll be quite angry when you hear it: When you open the lamp door on the back of the TV, youll see a small toggle type switch that gets pushed in when the door gets re-installed and allows the TV to turn on. This is to make the power shut off in case someone tries to access the lamp with the set on. If memory serves, the toggle on my 50" samsung was blue I think. You can use duct tape or something but I actually used a very small zip tie to hold the toggle in place for a neater, less ghetto-fabulous fix. NEVER had it shut off by itself since.
Posted on Jun 24, 2009
My Samsung 50 in DLP began turning off spontaneously shortly after we purchased the set nearly 5 years ago. This problem has recently become more frequent. This afternoon I secured the blue switch with a plastic tie and the tv has not turned off since. Your problem sounds different from mine. Mine simply turned off - no flasing lights.
I talked with Best Buy earlier today and they told me that in some Samsung sets the problem was solved by a software update. If your set has a USB port you may be able to get this update directly from the internet.
Posted on Aug 03, 2009
Samsung tv turns off on its own model hls4266wx
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Mar 12, 2010 | Samsung HLS4266 TV
    My Samsung DLP model HL-P6163W keeps turning on and off and now lights are flashing. We replaced the color wheel last year and about two years ago the lamp.
    could still be the lamp but it could also be the Ballast for the lamp has failed. I've replaced a lot of Ballasts on DLP machines.
    Nov 17, 2009 | Samsung 61" Slim-Depth DLP HDTV
    I have had this Samsung DLP HL-P 4663W for about 3 years now.
  • Sep 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    My 56 inch Samsung DLP keeps shutting off. I have
    Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
    Sep 02, 2009 | Samsung DLP HL-P5663W 56" TV
    My 56 inch hi-def projection samsung tv turns off automatically
  • Mar 06, 2009 | Samsung DLP HL-P5663W 56" TV
    TV TURNS OFF AFTER 20-30 MIN
    May 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
    PROBLEM WITH SAMSUNG DLP TV
    It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
    Apr 07, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
    TV turns off by itselft
    Feb 27, 2008 | Samsung HL-S6186W 61" HDTV
    Samsung DLP HL-P5663W 56" TV Logo
    654 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
