Question about Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher
Samsung DW5933RASR heavy load light blinking - Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher
Samsung dishwasher heavy and delicate lights blink and cycle stops
The lights that are blinking are indicating an error code--the particular code you describe is a "heater error". You will have to check the circuit for an open heater element, loose or broken wire, defective main control board. The part number for the main board is DE92-02256C. Hope I helped you!
Aug 07, 2015 | Samsung DMT400RHS Builtin Dishwasher
Why is the heavy light blinking on my samsung dishwasher
That is usually indicating a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Aug 03, 2014 | Samsung Dishwashers
My GE spacemaker washer is blinking and will not work
I have a he gtup270emww washer used very little. The washer was overloaded and quit working full of heavy wet clothes and water. The washer agitator does not operate. The water does not drain.
The light blinks. I have un plugged the washer to reset the motor and lifted and closed the lid 7 times. I drained the water by hand.
When I try to operate the washer, it adds water for 30 seconds, the water shots off and the green light blinks.
What is the fix?
Mar 24, 2013 | GE Spacemaker Washer and Dryer Electric...
How do I reset a samsung dmt300 dishwasher
i have a samsung DMT300 Series. The heavy light keeps blinking. How do I reset it? It was leaking water and I believe we fixed it. What can I do?
Sep 12, 2012 | Samsung DMT300RFW Builtin Dishwasher
All my lights on the front of the dishwasher are blinking at me & stops running after 3 minutes into the cycle. What is the cause of this & of course, I am two months past my warranty. Help.
If three lights are blinking (normal, heavy, quick)... I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
Jan 27, 2012 | Samsung DMT300RFW Builtin Dishwasher
Kenmore 24 in. 16259 / 16254 / 16252 Built-in Dishwasher Logo
11 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
