Question about HP Office Equipment & Supplies
Error olivetti olivetti d-colormf3000, trouble code 0502
SOURCE: Error 0502
I did as suggested by another poster, clean the area of travel(ribbon,travel bar, etc) with a clean damp cloth and now it seems the problem has corrected it self
so far anyways ........
Posted on Dec 13, 2007
  • 41 Answers
SOURCE: error #0502
The steps below will help you to identify and resolve each of these four issues.
pattlnk_4242006_196-lable.jpg Legend:A: Encoder Strip (semi-transparent grey strip)
B: Carrier Belt (black and brown toothed belt)
C: Cartridge Carrier
Troubleshooting Steps
Cleaning the encoder strip
WARNING! Be very careful when cleaning or adjusting the printer's encoder strip.
Required materials
You will need a dry, soft cloth
Embedded links in the table will take you to specific troubleshooting steps.
Step Action 1 Turn the printer off and disconnect the power cable from the back of the unit. 2 Open the printer's front cover.
Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer.
pattlnk_4242006_1911-beltmove.jpg 3 Remove both of the cartridges. 4 Move the cartridge carrier over to the left-hand side of the printer using the carrier belt. 5 Gently clean the encoder strip with the cloth. 6 Move the cartridge carrier back to the right-hand side of the printer using the carrier belt. 7 Reconnect the power supply and turn the printer back on. 8 Perform the printer hardware test. Click here for instructions.
Did the printer pass the hardware test?
If yes, proceed to step 9.
If no, proceed to Reseating the encoder strip.
9 Power the printer back off and disconnect the power cable from the back of the unit. 10 Open the printer's front cover.
Move the cartridge carrier over to the middle of the printer using the carrier belt.
11 Reinstall the printer cartridges and move the cartridge carrier back to the right-hand side of the printer. 12 Reconnect the power supply and turn the printer back on. 13 Perform the printer hardware test.
Embedded links in the table lead to specific troubleshooting steps.
Step Action 1 Turn off the printer and disconnect the power cable from the back of the unit. 2 Open the printer's front cover.
pattlnk_4242006_1911-beltmove.jpg 3 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and then back up to get it into the slot. If the strip is completely out of the slot, it may be necessary to move it first forwards and then back.
pattlnk_4272006_149-reseatenc.gif 4 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer hardware test.
If yes, proceed to step 9 of Cleaning the encoder strip.
If no, proceed to the Black/Photo cartridge troubleshooting steps.
Black/Photo cartridge troubleshooting steps Embedded links in the table will take you to specific troubleshooting steps.
pattlnk_4242006_1911-beltmove.jpg 3 Remove the black/photo cartridge. 4 Move the cartridge carrier back to the left-hand side of the printer using the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer test.
If yes, repeat steps 1-7 with a new black/photo cartridge.
If no, continue to Color cartridge troubleshooting steps.
If you attempt the steps with a new black/photo cartridge and the error persists, proceed to Contacting Lexmark.
Color cartridge troubleshooting steps Embedded links lead to specific troubleshooting steps
pattlnk_4242006_1911-beltmove.jpg 3 Remove the color cartridge. 4 Move the cartridge carrier back to the left-hand side of the printer using the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer hardware test. Click here for instructions.
If yes, repeat steps 1-7 with a new color cartridge.
If no, proceed to Contacting Lexmark.
If you have attempted the steps with a new color cartridge and the error persists, proceed to Contacting Lexmark.
Posted on Feb 21, 2008
Roop1980
  • 228 Answers
SOURCE: hardware error 0502 and error code 50c
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. Lexmark will replace the printer, only if it is under warranty.
Posted on Apr 26, 2009
ramminnathan
  • 70 Answers
SOURCE: error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Posted on Feb 19, 2010
pineworks
  • 4041 Answers
SOURCE: Hardware error code 0502 how to solve this
Hi there
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 25, 2010
Testimonial: "thank you very much.sofar it works !!!! 4 stars !!!!"
Kinko Minolta Magicolor 1690MF. What is error code 0502?
If you wish to get some details; check the site linked here. Pull up older posts. check for printers and copier articles .........
http://electro-medical.blogspot.com/
Apr 10, 2016 | Office Equipment & Supplies
Olivetti d-copia 16w error code H4
I need driver olivetti_d_copia_16w for winXp....
Sep 25, 2012 | Olivetti Office Equipment & Supplies
My Lexmark X6170 won't print or partially prints e-mail. Also it won't copy in black but will copy in color? When this happens I get the 0502 error message. Any idea as to what is wrong and how to...
The 0502 error code indicates either a faulty cartridge is detected or the encoder strip (transparent strip) is dislodged from its position. Refer to this article in the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display to determine and resolve the problem. Thanks.
Feb 16, 2011 | Lexmark X6170 All-In-One InkJet Printer
Error message: HARDWARE PROBLEM ERROR CODE 0502 Only prints top part of page and then gives error code raabe@shaw.ca
Refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. If error continues even after following the steps, contact Lexmark technical support for additional assistance. Thanks.
Jan 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
Printer error 0502
The 0502 error code could be caused by an unseated encoder strip or a faulty cartridge. Please refer to this article Error 0502 on the Lexmark X5130/X5150/X5190 Pro LCD Display for the troubleshooting steps. Let me know if you need further assistance. You can also contact Lexmark technical support for additional assistance. Thanks.
Nov 11, 2010 | Lexmark X5150 All-In-One InkJet Printer
Error code 0502 hardware error on dell printer
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
Hi i am having trouble finding a windows 7 driver update for my Olivetti Anyway photoplus, can you help.
Olivetti currently does not provide Windows 7 drivers for this device. However, often Windows Vista drivers work under Windows 7 as well. Give the Vista driver from http://www.olivetti.com/site/public/support.asp?sid=1&code=B9352 a try.
Feb 07, 2010 | Office Equipment & Supplies
Error 0502
Please click on this link:
then type in the printer model in the selection X6170 and then choose Lexmark X6170 and support page will open then you need Error type 0502 and you will get it trouble shooting steps...
http://support.lexmark.com/perl/support/support.cgi
Good luck...
Aug 12, 2008 | Lexmark X6170 All-In-One InkJet Printer
Error 0502
Dec 10, 2007 | Dell A940 All-In-One InkJet Printer
16 people viewed this question
Seeker5211
Seeker5211
