Question about Refrigerators
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in as soon as I did that the rcd tripped I unplugged everything in the house and plug the fridge in it done it again it trips the rcd as soon I flick on the switch any advice on what might be wrong as it is very expensive to call someone in to look at it when we moved it from the garage to the house there was a little bit of water coming out from under it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
With the unit unplugged remove the machine compartment and visually inspect for and burnt marks or frayed wiring. if non is seen, remove the wiring connectors from one component at a time and re test by plugging the unit back in. This will help you isolate the issue hopefully.
The machine compartment is on the back and the power cord is attached behind it. It is usually connected with 1/4" screws so a socket or nut driver will help you gain access.
Posted on Apr 23, 2014
2 Suggested Answers
  • 62 Answers
SOURCE: I have an Amana SRDE528TB
Sorry to say that the most likely cause of this problem is a bad compressor. Many Amana's have the same problem. In dealing with these units I find that will run for a while then have trouble starting up. In your case you are using a ground fault circuit and the extra current draw is causing the house breaker to trip, although most manufactures suggest that you don't use that type of circuit. The only real way to correct the problem is to replace the compressor, or get another refrigerator. The compressor replacement should be done by a qualified technician.
Posted on Aug 30, 2008
Why won't my fridge cool properly
This happened to me also, I had to let refrigerator defrost all the way by unplugging it. The lines that carry the freon had frozen so they were not circulating properly. I had to buy ice and use coolers for food, then wait till next day before plugging unit back in.
Apr 24, 2014 | GE GSS22SGM Side by Side Refrigerator
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
Rcd tripping
Either the start relay in the compressor is grounding electrically or the defrost heater is (most likely start relay). To replace this yourself is difficult as it requires technical knowledge. If you are located in California, bay area I could help you personally
Apr 21, 2014 | GE Profile PSW26P Stainless Steel Side by...
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge and freezer cools when it wants to - freezer on top
hard to say, there is many questions left that need answered...does the compressor run, does the fans run? what more could you tell me.... whirlpoolpartssurplus.com free tech support
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Does not hold temperature, warms up.
if you hauled on its side then it is very possible you have oil in evaporator. replace all sealed system parts. compressor, drier and evaporator.
Jun 21, 2009 | Roper Refrigerators
Ge profile brita 18 bm black purchased in jan/06
Having the same problem. apparently this is just a horrible fridge... unfortunately no solution for ya
Jan 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
