Question about Samsung Computers & Internet
Laptop speaker not working
Speaker not working, external speakers are working
iqbal_del
  • 655 Answers
SOURCE: Compaq Evo N610c No internal sound
No, you need not to install soud/audio driver if its work with external speakers. Its seems that the internal speaker of your laptop has got damaged. So you shuld call your vendor for service. If you are in warranty it will be free for you.
Thanks
Iqbal
Posted on Mar 08, 2008
ginko
  • 19396 Answers
SOURCE: can't mute inbuilt speakers
That is not a software problem.
The headphones/external speakers jack socket has a switch to exclude from audio the internal speakers, when a jack plug is connected.
This is a very simple device and is not software controlled.
The fact that it has gone faulty at the same time you reinstalled the system is a coincidence.
If it does not mute when you insert headphones, all you can do is trying to play with the jack plug , inserting and pulling it out. If this does not unlock the switch, the alternative is having the jack socket replaced by a technician. This is generally an expensive repair, asthe socked is soldered on motherboard.
A cheap alternative to a proper repair is using an external USB to Audio Adapter and mute the internal audicard when using headphones.
Posted on Oct 19, 2008
  • 67 Answers
SOURCE: my Toshiba U205, no sound from laptop speaker
because it could be on mute
Posted on Jul 01, 2009
  • 1099 Answers
SOURCE: external speakers do not work on my MacBook pro
Plug in your external speakers then go to system preferences then sound when in the sound control panel go to the output tab and select the external speakers as the device for sound output and of course at the bottom of the control panel make sure that the mute check box is unchecked and turn up the volume. Hope this helps
Posted on Oct 10, 2009
  • 58 Answers
SOURCE: Speaker randomly works
Please check the link: http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
Hope it helps.
Posted on Nov 04, 2009
No sound
Your computer's external speakers are either disconnected or damaged. Let a computer technician repair them or use headphones/external speakers.
Take care!
damnor01
Sep 12, 2012 | Acer Aspire 5050 5430 Laptop
My HP 610 laptop's inbuild speaker is not working,but with the external speaker it is working.I want to know the price of HP compaq 610 inbuild speaker.
Try the following steps:
Open your laptop carefully (look out for fragile ribbon cables) !
Check for a broken wire going to the internal speaker.
Check for a faulty contact at the audio output jack (these things have a contact which disconnects the internal speaker when a plug is connected).
Temporarily connect any speaker in the place of the internal speaker.
If the problem is still the internal speaker, remove it and go to any good audio components shop and buy an equivalent speaker.
Hope this helps.
Nov 25, 2011 | Computers & Internet
Having problems getting sound from internal speakers after having used external ones, any suggestions?
Hi, I understand that external speakers are working but internal speakers are not working on your laptop.
This could be due to the socket you are using to connect external speaker. if the socket's inside contacts looses the contact it cannot internal speakers.
Thanks,
Shiva
Dec 18, 2010 | Apple MacBook Mac Notebook
My speakers don't work, I can plug in head phones or external speakers and they do work. it started after my son repeatedly pluged and unpluged the external speakers
There is a microswitch in the speaker jack of the system. It disables the on-board speakers when external speakers are connected. If sounds like that switch is stuck and the on-board speakers are staying disabled when the jack is removed.
Jan 30, 2010 | Dell Inspiron E1505 Notebook
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
External speakers do not work on my MacBook pro
Oct 08, 2009 | Apple MacBook Pro Laptop Computer with...
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
External speakers for acer laptop 5220 series
Hi there
On acer laptop you have already speakers. but you want to connect external speakers then please find
that three conector in your laptop and connect you external speakers on one of them. please try each connector and you are able to connect external speaker.
Thanks
Robert
Sep 24, 2008 | Computers & Internet
Hi, My speakers won't work on my "Vista" laptop. I have made 3 trips to bestbuy. "it's 20 miles round trip." The geek guy got them working,when I play DVD movie. befor they worked on...
Your Majorgeek seems to have been a Minorgeek. When you purchase external speakers to use with your laptop, you must configure your laptop for them. Since your system appears to have worked before you tried to use external speakers, I doubt that you have a problem with your sound device driver. Still,
go to control panel,and check device manager to see if you have any problems. If you have a problem flagged, let me know. If not, click on Hardware and Sound, then on Sound, and see how your laptop speakers are configured. Majorgeek should have turned off your internal laptop speakers and configured them for your external speakers. If they didn't, that likely explains your problem. Configure them and test the sound there.
If you need to use your laptop speakers (say you take your laptop somewhere without your external speakers) you will need to reconfigure your sound to the laptop speakers whenever you need to use them. Let me know if this solved your problem.
Jul 12, 2008 | Logitech X-530 Computer Speakers
Thanks
Iqbal
Mar 05, 2008 | HP Compaq Evo n610c Notebook
Computers & Internet Logo
14 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
