Question about Kenmore Refrigerators
After the fridge was transported lying on its back it now will not cool
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Freezer works fridge not cooling on a Danby Designer fridge
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Jul 30, 2009
SOURCE: after a power outage the fridge stopped cooling
I have the same problem,please let me know when you get and answer as i will do the same,katitjam@yahoo.com
Posted on Sep 02, 2009
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
Fridge not cooling. Shifted house 2 days back. Before it was alright.
Your fridge systems under chocked. Whenever transport refrigerant unit you should not lift down wards on suction side which will lead compressor oil thr' discharge line. When compressor on, it will pump the oil.It get chocked on filter drier resulting to no cool.
Solution. Remove all gas, and also filter drier. Now flush out condenser side separate and evaporator side separately.Then replace filter drier and vacuum the system.Now do gas charging. Thanks. helpful?
Jan 30, 2011 | LG LRFD25850 French Door Refrigerator
I have a stainless steel Amana model ABC2037DES that was given to me. It has been plugged in for 24 hours and it is not freezing anything or making ice. The refridgerator is not cold enough either. ...
if the compressor is working it could be a thermostat problem
I think that if you check for a reset button at the back to get the compressor running , that will fix the problem
Mar 13, 2017 | Amana ABC2037DES Stainless Steel Bottom...
Fridge not cooling,unfortunately collected by car and the fridge was transported on its side.Its been off and standing for days but still not cooling when switched on,is there a remedy
It is possible that the compressor oil had pumped into the system and is thereby causing problems in the heat exchange cycle.
Put the fridge off and keep it standing for more than 24 hours to allow the oil to come back to the compressor.
After the time limit put the fridge on and watch the noise of the compressor to be pumping earnestly with a good whining. If not check onthe main capacitor or relay( if clicking).
If there is no ICe formation in about 2 hours, it is possible that the compressor is weak , gas is leaked and needs an overhauling.
Sep 16, 2010 | Refrigerators
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
Bought this model from someone new, it was working great when I checked it out, transported it to our house and plugged it in the next day. Freezer works well but fridge barely cools at all. Any...
HI There,
If it was transported to to your house not in an upright position, then you may need to unplug it and wait for 8 hours to have the fluids settle before starting it again. If that is not the issue, ensure that there is ample space at the back of the unit, between the wall and the fridge to help circulate the air. Inspect the coil found at the back of the freezer for ice build up or dirt. If there is let it melt and have the unit cleaned out first before restarting.
Aug 22, 2009 | Refrigerators
Freezer works, but fridge barely cools.
there is a "box" looking thing inside fridge. A fan sends cold air into the fridge. See if the port is blocked/iced up
May 25, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerator not cooling
My fridge and freezer just stopped cooling all of a sudden. I hear the compressor running and every couple of min there is a clicking noise. Is there a reset switch or something that I can do to start it working again? The lights are working but the freezer and fridge are room temp.
Jun 22, 2008 | Refrigerators
Refrigerators Logo
13 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
