Question about Galaxy Aqua 2000
AQUA 2000 HAS NO POWER TOTALY DEAD
THERE IS NO POWER ATALL NO LIGHT COMING ON THE SYSTEM HASSHUT DOWN I CAN ONLY PRESUME THAT THE FUSE HAS BLOWN ON THE MAIN CIRCUIT BOARD
Stand by light wont come on after power cut
Not knowing the model first is if total dead follow power cord inside the set (presume you can safely take back off) and to the fuse---look for a blown fuse where cord connects.
If not able consider a technician looking at the set for you.
Nov 05, 2012 | Televison & Video
Car is totaly dead put new battery and alternator on it drove for a day now totaly dead again like battery has been disconected
Check glove box / boot light. Temporary remove them charge batry & see if discharge stops.
Jun 18, 2012 | 2000 Ford Mustang
My green light does not come on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_15_2012_1_33_36_pm.jpg
May 15, 2012 | Westinghouse W33001 30 in. HD-Ready LCD...
2000 ford taurus wont start. When the key is turned I have no dash lights, or power to the accessories that run through the ignition. I changed the ignition switch today. Thank You Chris
Is your dome light coming on? do the power locks work?
Your battery may be dead, or you may have blown a main fuse (under the hood)
Mar 09, 2011 | 2000 Ford Taurus
Microwave is totaly dead
YOU WANT TO CHECK POWER FIRT AT THE OUTLET MAKE SURE YOU STILL HAVE 120 VOLTS THERE.. IF SO AND PLUG IS GOOD ON 98% OF THE MICROWAVES OUT THERE IS A 20 AMP fuse located in control panel of unit... check there with the power disconnected and may have a blown fuse...if that is good you most likely have a blown control on unit ...
hopw this helps good luck...
Jan 05, 2011 | Hotpoint RVM1325BW Microwave Oven
System will not turn on
Can you borrow a friends power supply and try it? I presume you checked the fuse in the plug socket (If a UK plug.).
There is a fuse in the power supply which could have blown.
There is also a fuse on the power inlet on the Wii motherboard (it is coloured green). That could have blown.
After that there are over 40 fusable links on the motherboard!
Jul 24, 2010 | Nintendo Wii Console
My lcd al 1717 not working totaly dead plese help me...............
You need to open it up and inspect the power supply for blown fuse first, then look for bad caps with bulging top or leaking liquid. Post back what you find so we can guide you further, see example of failed monitors due to bad caps:
Feb 27, 2010 | Acer AL1717 17" LCD Monitor
Radio/dvd/cd not working since battery died
alot of newer cars have an anti theft system for the radio and when you lose power you have to enter a code into the radio so you may have to call the dealership to get it
Apr 11, 2009 | 2009 GMC Acadia
TOTAL SHUT DOWN
This has to be a blown fuse. If it happened slowley you lost your altenator or battery connection.
Jan 07, 2009 | 2003 Harley Davidson FLHTCUI Electra Glide...
Galaxy Aqua 2000 Logo
Top Galaxy Home Experts
Donni Steen
Tom Chichester
Are you a Galaxy Home Expert? Answer questions, earn points and help others
