Oil light on when I start, I shut off and light stays off
The oil light is supposed to come on when there is low oil pressure, so when the car starts, the pressure goes from 0 to whatever (25-60psi depending on the engine). As a result, the light stays on for a few seconds at the beginning of the start cycle and is then supposed to go out. If the low oil pressure light remains on, then you either have low oil pressure or you have a sensor problem. If you have low oil pressure, you may need a new oil filter. If the filter was just replaced, then you need to get professional help because low oil pressure will wreck your engine in a hurry. Your engine's oil pump may be faulty and need to be replaced.
Aug 19, 2013 |
2004 Chrysler Pacifica
