Question about Canon LV-X4E Compatible Projector Lamp
Canon lv-x4e lamp reset procedure
Projector lamp npt glow & lamp replease indicator glow please procedure lamp reset
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Posted on Jul 28, 2015
dhiman
  • 115 Answers
SOURCE: canon lv-7220 inverted view.
Yes,
Go to the menu and setup the prj mode.and the image will be inverted.
Viren
Posted on Nov 27, 2007
dhiman
  • 115 Answers
SOURCE: cannot reset projector after new lamp installed
hi
Have you reset the lamp timer after replacing the lamp, if not then do so and see the user manual for that.
Viren
Posted on Feb 07, 2008
Marrie
  • 563 Answers
SOURCE: lv-s1 canon projector
Hi there
Open up the unit and replace the fuse on the Powersupply ( where the AC inlet sits )
If this doesn't do the trick you will have to replace the Powersupply itself.
But most of the time it is only the fuse that has gone.
Posted on Apr 15, 2008
old marine
  • 2153 Answers
SOURCE: Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
Posted on May 20, 2008
lbrown1806
  • 488 Answers
SOURCE: Canon LV-S3 how to check hours on the lamp? do I
Lamp Replace Counter
Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting.
Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced.
1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon.
2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed.
Move the pointer to [Yes] and then press SET button.
3. Another confirmation dialog box appears and select [Yes] to
reset the lamp replace counter.
This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard.
 Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps.
 If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down.
( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion.
 A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and
lamp are being used.
IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN.
If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that
there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector
except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an
accident or injury caused by pieces of broken glass.
Posted on Dec 24, 2010
Rectification of Power Supply Unit of CANON Projector Model No : LV -S4 Serial No : T701182A
the power supply unit is USD60
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 15, 2014 | Canon LV-LP12 Projector Lamp for LV-S1,...
Power Supply Unit of CANON Projector LV-S4 COST PRICE
power supply foe lv s4
usd60
Have a nice day!
Lampdeng Limited
Jerry
Feb 15, 2014 | Canon LV-LP23 Projector Lamp for LV-S4
CANON PROJECTOR LV-S4 POWER SUPPLY UNIT
power supply for S4 ,Unit price is USD65
have a nice day!
skype:lampdeng
Canon lv- x5
Have a nice day!
Lampdeng Limited
Jerry
Jan 15, 2014 | Canon LV-LP12 Projector Lamp for LV-S1,...
Canon LV-S1 projector keeps shutting down after a minute or less
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
Canon LV-S3 how to check hours on the lamp? do I have to have unit hooked up to an input source?
Dec 24, 2010 | Canon LV S3 Lamp
Projector won't power on. Plug it is and all I get
the lamp is past 2000 hours and needs replacing and the timer needs resetting.
Aug 17, 2009 | Canon LV-S2 Multimedia Projector
Need to replace lamp in canon projector lv5210 need to know how t
Manual is available for viewing/download here. Instructions for changing the lamp are on page 43, and for resetting the lamp counter on page 44.
Jan 29, 2009 | Canon LV-5210 Multimedia Projector
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Cannot reset projector after new lamp installed
hi
Viren
Jan 24, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Canon LV-X4E Compatible Projector Lamp Logo
279 people viewed this question
old marine
old marine
