Question about Kitchen Ranges
Westinghouse freestyle 418 LPG or propane gas oven. Flame burns with a yellow tinge, pops and carbon builds on ignition system
Oven flame pops, burns with yellow tinge, is uneven and carbon builds up on ignition
4 Suggested Answers
  • 95 Answers
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Posted on Jan 24, 2009
Kgt1962
  • 59 Answers
SOURCE: Whirlpool gas oven-Super Capacity 465
When you turned the oven off, if the ignitor went off and the gas kept flowing then the thermal valve is defective. Maybe that was the problem all along.
Posted on Mar 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: i am converting from natural gas to l.p. gas and i
Tighten down the nut on top the safety valve till it bottoms out. Then adjust it. The air shutter needs to be adjusted as well. You must do this while the oven is lit. The flame needs to creep no further than half way up the spreader. Ye must get the proper air to gas ratio and the only way to do it is to tinker away at it while the oven is lit.Crank down and flip machines are very simple to convert. NOTE: new gas safetys do not come factory set. They come tightened down (b Turning the orifice counter clockwise allows more gas , turning it clockwise allows less gas. Since the bi-metal safety is a slow opener that explains why you have a nive flame to start and then as time goes by the flap opens and allows for an overshoot of gas. tighten the valve clockwise to get the flame set as soon as you notive yellow. By the way I am sure a propane guy from your supplier would be willing to help you get it in tune if you feel a bit shakey about laying on the floor and adjusting the flames on an oven.
Posted on Apr 09, 2009
Why does my westinghouse gas oven ignite, go off, ignite again, off,on, off, on, before temp is reached?
dirty gas orifice in the oven near the burner clean it and try again
Jul 22, 2017 | Ovens
Convert dcs oven pilot from propane to gas 36-6-1CL
changing from propane to LPG requires the services of a gas fitter
it is a jet size change with air shroud adjustment to get the correct flame color burn
Nov 06, 2016 | DCS Kitchen Ranges
How to adjust flame on Westinghouse freestyle gas oven
The flame is regulated by the thermostat you don't say if it's too high or too low. Suggest you buy an oven thermometer available for a few dollars at most homeware shops, compare the temperatures then you will see if the thermostat is working or not.
Apr 22, 2014 | Cooktops
Gas oven flame yellow not blue like grill and hob rings.Flame is floppy and laboured and doesn't shoot up when turned up,could this be the thermostat Regards F Daley
Normally not the thermostat. Blue flames signify that the gas is burning clean, a yellow flame signify that some contaminate is burning with the gas. I would guess that something has leaked onto the burner or you have some corrosion build up. Try taking it out and giving it a good cleaning with a soft bristled brush and see if that is any better.
Jul 01, 2011 | Ovens
WE HAVE A NUMBER OF LPG IMPERIAL IFS40 FRYERS WITH A VERY LARGE FLAME ESSESIVE FOR THE UNIT FLAMES BURNS AND EXTENDS AT THE BACK OF THE FRYER INTO THE FLUE . WE HAVE CHECKED THE CORRECT INJECTOR , CORRECT...
check the burner orifice and gas valve spring kit if it is suited for propane use.remove carbon build up inside the fire tubes.check also if the gas pressure is correct.
Mar 11, 2011 | Imperial IFS40 Deep Fryer
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
My oven burns with a yellow/orange flame How do I adjust it to burn with a blue flame
Sound like the igniter is not reaching the correct amp draw, so it is not opening the gas valve all the way. Watch this video on troubleshooting a gas oven. www.appliancehelponline.com/servicemanual.html
Mar 03, 2010 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
I have a gas oven. The flame burns yellow and leaves too much soot on the wall near the flame. Is there a way to clean the element thing? Dave
I am not sure. However, people in our area of sc, have had burner problems because a local utility added propane to their natural gas because they got it a bargain. guy
Jun 10, 2009 | Frigidaire FGB24S5A Gas Single Oven
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Kitchen Ranges Logo
22 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
