Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Electric clutch on my 4 yr old Cub Cadet 2518 was intermittent
Now it just quit I heard a rattling type noise & it looks like it move a bit but won't engage the mower deck
  • 22 Answers
Check fuse or power it up seperatly with 12volts (battery directly into the two terminals) to see if it is a wiring fault but it sounds like you need a new clutch assembly $$$
Posted on Jun 20, 2009
LGTX 1050 Cub Cadet PTO will not engage blades on mower deck
If its an electric clutch it may not be getting power use a test wire from batter touch it to clutch and if you here it engage its ok sometimes the get corroded a bit and wont lick in but sounds like no power to clutch.
Apr 05, 2017 | Cub Cadet Garden
Cub cadet lawn tractor
MOST likely cause is a worn/failed drive belt. I'd replace that first - be SURE to use a Kevlar belt or you'll be repeating the repair in a very short time frame.
Jul 15, 2013 | Cub Cadet Garden
Cub Cadet 2518 48
look for a binding pulley
Apr 03, 2012 | Cub Cadet Garden
My electric pto is not working properly. It shuts off and does not turn back on when theswitch is pulled
I've had the same problem. Intermittent shut-off of the pto. Found out that the pto (electric clutch) draws heavily on the battery current to stay engaged.Clutch is actually an electro-magnet. I bought a new battery (300 cca) the bigger the better and clutch now works fine. Old battery was still strong enough to start engine but not strong enough to engage pto. Old battery was 4 yrs old. A good clutch will click if jumper wires from the battery to clutch wiring harness are connected (with out motor running.)
Jun 02, 2010 | Oregon Scientific Electric PTO Clutch for...
Hi i have a cub cadet 2518 and my pto belt keeps breaking (2) belts today 4-15-10 and only one in years past ??? what could be the problem ??? ty don
siezed pully bering check to see if there is a grease fitting if not get PB BLASTER best stuf ever made to loosen up tough stuf
Apr 15, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My Cub cadet pto cluch bearing is froze up on my 2518 lawn tracto
A medium length extension (stuck through the grill), a swivel and an impact is all you need to remove the pulley with the frozen bearing. It's just a bolt, a washer, and a lock washer holding it on. You just need to remove the pulley to see if the bearing is stuck. Take the pulley to your local shop that can press bearings and you can be up and running for $20 dollars instead of $300. Here's a diagram I found on partstree:
http://www.partstree.com/parts/?lc=cub_cadet&mn=2518-48+Tractor&dn=0043700012
Apr 08, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet wont engage blades to cut grassmower iz rtz 50 zero turn tried to move the wires around and checked the 20 amp fuse no shorts. was cutting fine i just stopped to dump the bagger. any help would...
Try this:
With the engine turned OFF, unplug the wire connector at the PTO clutch, and use an alternate 12 volt DC power source and some alligator clips to manually power-up the clutch. If a firm, crispy "Click" is heard each time you "power-on / power-off" the clutch, then safety switches on the tractor are the most likely suspects.
If no firm, crispy "Click" is heard, your PTO clutch needs to be replaced.
On the right-hand side of THIS page, type in (without spaces) RZT50 and you will be given a list to choose your EXACT machine & part number.
Special Note:
If your part number description says to refer to "Service Advisory ...(blah blah)" then you will need to call a servicing dealership for the proper replacement part number.
Hope this helps.
Oct 04, 2009 | Oregon Scientific Oregon Gator Mulcher...
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
540 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
