Tcl tv wont start green light just flashes
4 Suggested Answers
  • 6 Answers
SOURCE: The Green Light start up will flash but the TV wont turn on
http://www.chrisandnat.com/projects/BlinkingTV/Blink.htm
Posted on Sep 02, 2008
  • 75 Answers
SOURCE: "timer"flashing green light
should check then capastors on the dm board. they are on a board in a silver case on the left side of the set when looking from the rear. the capstors should have 16v @ 1000u wrote on the side of them and are about 1 inch tall size of a dime round. Dont do anything without unpluging the tv frist from power. Just to let you know I have posted this before.You can use 25v/1000u if you cant find the 16v/1000u. You can higher in voltage and be ok but donot go less than 16v rateing. this is what i would check out frist.
Posted on Jan 02, 2010
SD Tech
  • 14553 Answers
SOURCE: the tv wont come on the green light just keep flashing
Power supply needs to be first checked:
some information:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
Posted on Jun 11, 2012
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Tcl l32m19 tv wont turn on woke up the other day and the light on the front was not on
Power supply regulator section [mains] to your TV should be troubleshooted. This is a skilled work.
Jun 26, 2012 | TCL Televison & Video
TV can not power up. Power button flashing, turns in green but no audio & video
I have a PDP 50 V8 plasma TCL tv
Turns green and back to red
Ive been told its the power board
Dec 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Green timer light wont go away
Hi.
The TV is in protect mode because there is an internal fault.
The TV must be tested and repaired at component level.
Call Mitsubishi at the number listed on the user manual.
You can also read my comment explaining more on protect mode here:Why my TV does not start up and remains in...
Dec 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Flashin power light - wont come on
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Oct 05, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
