Question about Frigidaire FAM157S1A Air Conditioner
FAC107P1A Not cooling. Drilled drain hole
    Problem Solver:
  • 18 Answers
DRILLED INTO COOLANT LINE WILL NEED TO FIX AND RECHARGE
Posted on Apr 22, 2014
Testimonial: "We had a guy come out and he used 15% sauder & he also installed a Schrader valve. He filled it with the required amount (I hope) of Freon and vacummed it. We blocked the drain holes created as this unit isn't suppose to have drain holes. Now, the unit is still blowing warmish air but then it will blow cold air if I put it on fan for a few minutes and then back to cool, it blows pretty cool air. Weird.. not sure what's up now. Thanks for you help!"
I have a small 5000 btu window unit air conditioner made by arctic king does not have a hole for the excess water to drain.
I've repaired a lot of window units because someone has drilled a hole in the pan, to drain water, and hit the coil. Please do not drill any holes in anything! These units utilize condensate water to help reject the heat in the outdoor coil. If water is reaching the outdoor fan, it either does not have the proper "lean" or slope, or it's designed to allow water to reach the fan, and not much you can do. If it is designed to allow water to cool the outdoor coil, and you were to drain that water so that no condensate water cools the outdoor coil, this will allow the unit to operate with an excessive outdoor coil temp, and shorten the life of the compressor, or cause the unit to operate poorly/warm supply air temp. Try to give it just a little more "lean". Hope this helps!
Aug 18, 2017 | Heating & Cooling
Artic king 12k btu wall unit it doesnt have drain hole in bottom of the unit an inch of water sitting in the unit and it wont drain. Is this normal? inch high lip in the back of the unit. Drill hole?
By all means. That water should not really be collecting there - it can eventually overflow and wind up in the room being cooled. And if you want to be fancy you can insert into the hole some clear tubing you get from Home Depot with an OD a tad larger than the hole you drilled and direct the flow of evaporator water via gravity to where ever.
Sep 05, 2015 | Heating & Cooling
2004 jeep grand Cherokee a/c evaporator case extremely wet behind glove box dripping water on floor and in glove box, condensation from running ac, drain is completely clear
Since it was drilled-- verses-- making the proper fix in the past
Your ONLY option-- is completely remove as much as necessary,
until you have found ALL problems & butchered work & reassemble correctly & replace that drilled item
Nov 09, 2014 | 2004 Jeep Grand Cherokee
Ac drips inside
Tip it outward so the concensate will tend to overflow outside. Be careful you dont drop it.
Typically, window AC will collect the water in a tray to help cool the bottom ocondenser and rely oin evaporation to get rid of the water. Sometimes, during high humidity, it doesn't evaporate quickly enough and will spill out of the pan.
You could drill a hole in the pan outside ... whicl will drain the water ... but reduce the efficciency.
Interesting - I just got your request for a chat ... here is your answer ... and you didnt have to pay for it.
Sep 05, 2011 | Frigidaire FAC107P1A Wall/Window Air...
Why isn't there drain holes in bottom of window air conditioner? I drilled a hole for water to drain. Is there a problem with this?
It shouldn't be a problem if you drilled the hole near the rear, outer edge of the drip pan and didn't accidentally pierce any of the mechanical above it. Also, be sure the rear of the unit is tilted down at least 1/4" to 1/2", so water will flow to it. Check the drain hole periodically, as they will become clogged over time.
Thanks for choosing FixYa.
Jul 23, 2011 | Haier hwr10xc6 Air Conditioner
Leak on the ac in my 2003 mitsubishi galant
There is a drain hole just right (as your driving) of the steering column on the drivers side of the car. You can access this hole from the engine compartment. its right on the firewall. I just had this issue with my 2003 Galant (4 banger) and tried to dislodge the obstruction with a plastic tie, but it would not turn the corner to do the job. <br /> <br /> I then took the carpeting down on the drivers side of the car and found the tube. Its about 1/2 inches in diameter, black and at the lowest point of the plastic drain pan. I drilled a small hole in the tube and stuck a hanger into the hole to dislodge the obstruction. Since I used the plastic tie, I knew the obstruction was towards the cooler. Water started to flow out of the newly drilled hole and through the firewall drain hole. Once the water was drained, I plugged the drilled hole with gasket material. Let it set for a day and it was just like new. <br /> <br /> <br /> It tool about 20 minutes and was easy. Just make sure you drill the hole so that the wire hanger goes the right direction (towards the cooler). <br /> <br /> Good luck.<br /> <br /> Fran<br /> <!-- from fixya rte -->
Jul 05, 2010 | 2003 Mitsubishi Galant
Window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
May 03, 2009 | Frigidaire FAC107P1A Wall/Window Air...
CARRIER WINDOW AC IN INDIA
clean the drain system, find the restriction
Apr 21, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Leak repair Samsung window air conditioner
Modern window units intentionally do not allow the water to drain directly, they want the fan blade to sling the water on to the condensor (the coil that is outside) to aid in cooling actually helps the unit cool better in high outside temps, it also evaporates it this way, depending on where the hole was drilled it may be able to be repaired, if it was just a copper tube it will be less expensive than replacing the whole coil. Since its a relative inexpensive unit anyway the labor and freon may be more than its worth. Lesson learned dont drill a hole in the base it lowers it's efficiency and can lead to a punctured freon line.
Sep 29, 2007 | Heating & Cooling
Frigidaire FAM157S1A Air Conditioner Logo
57 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
