Question about Five Star Kitchen Ranges
Oven doesn't heat up on a Five Star Mod TTN525
Runs but doesn't heat replaced two fuses and magnetron still doesn't heat
Here is your free answer in under 10 minutes ...
You have a faulty door safety interlock switch. I wish you would have searched your problem here before you spent all that money on the magnetron. I have answered this question dozens of times here at this site.
When the oven runs but doesn't heat, more often than not it is nothing more than a faulty micro switch in the door latch system. When the switch doesn't work properly, the oven doesn't know the door is closed. If the door isn't closed, the oven will not energize the magnetron. Capacitors and magnetrons are **** and expensive answers but these items are extremely tough. It is the tiny contacts in the micro switch that can not stand the repeated abuse given them when we (read me in that number too) open the oven while it is energized causing a repeated flash across the contacts.
Thanks for your question @ FixYa.com
Aug 06, 2011 | Microwave Ovens
How to change bulb in five star convection oven? Bulb covered. How to remove cover?
Remove the outer cover by unscrewing the fixing screws. The lamp will then be visible for replacement.
Mar 21, 2011 | GE Advantium 120 Convection/Microwave Oven
We have a Five Star gas oven and attempted to use the self cleaning process to clean the oven. We started yesterday and it appeared to complete the cleaning cycle. This morning, however, the locking...
There are two reasons for the lock to remain locked. One: the thermostat/wiring failed. This results in the oven's control still believing that the oven is too hot (over 450 degrees) and thus will not unlock. The other possible problem is that the unlock mechanism failed.
You can try to unlock the oven manually. (For some ranges, you can do this from the back of the range.) Please add a comment with the model of the oven/range for more assistance.
I hope this gets you started on solving the problem.
Jul 06, 2017 | Five Star 48 in. TTN045 Gas Cooktop
Right oven won't light. it has power...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Five Star FiveStar 48'' All Gas, White...
An oven heating control system. schematic diagram? block diagram? the feedback operation in the control system? control objective? five basic element of the control system?
schematic diagram?
block diagram?
control objective?
Jan 04, 2010 | Saitek X45 Flight Control System (J24C)...
Do you have service people available in Rhode Island?? We have a Five Star stove with 6 gas burners, a grill, an electric oven and a gas oven.
Try A&E Factory Service,good people!
To schedule service or for customer service issues please call 1-800-905-9505.
Dec 02, 2009 | Kitchen Ranges
My Five Star Oven will not ignite and has NEVER been accurate (Low by 50 - 70 degrees)
You can remove the oven knob and inside the shaft is a small screw to tweak the temp. Ain't got no idear what type system you have so check these PAGES out.
Oct 30, 2009 | Five Star TTN280 Gas Kitchen Range
PRD486EDG doesn t heat up Oven light blinks once
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice. Tried reseting the power
Mar 18, 2009 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
Five Star Dual Fuel Range Issue
make sure the gas pressure is correct.get a small torch and heat up the flame switch (it sits above the glow bar)and see if the burner lights.
Aug 22, 2007 | Five Star TPN535-BGSW Dual Fuel (Electric...
Kitchen Ranges Logo
74 people viewed this question
Top Five Star Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ray gallant
Are you a Five Star Kitchen Range Expert? Answer questions, earn points and help others
