Question about Five Star Kitchen Ranges
Electric oven doesn't heat up. Yesterday it heated up to only 100 degrees and today it does not heat up at all
Tech007
  • 63 Answers
SOURCE: Electric Oven very slow to heat
cheak for 240 volts coming out of your wall if it reads 120 volts it is your house breaker
Posted on Aug 29, 2007
fridgetech
  • 473 Answers
SOURCE: oven slow to heat
In alot of ovens preheat will cause the both the broil and bake element to come on. You are most likely getting heat from the broil element. This means either the bake element is bad or the relay on the oven control is bad. If the element shows resistance with an ohm meter then replace the oven control board.
Posted on Oct 06, 2007
  • 213 Answers
SOURCE: ge oven...gas....not heating right
there is an ignitor bar that has to operate properly to open the gas saftey valve. the ignitor can glow but be weak so it wont open the gas valve. replace ignitor to slove problem
Posted on Nov 20, 2007
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile oven won't heat up
Check the temperature sensor with a OHM meter.
It should read 1100 ohms. If not, replace it.
Otherwise make sure the glow bar ignitior is coming on.
Ignitors however can glow and still be bad.
Posted on Feb 21, 2009
Oven won't heat above 100 degrees
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 23, 2011 | Electrolux Ovens
Maytag gemini wiont go over 100 degrees
heatman101
Apr 03, 2011 | Ovens
Turn the oven on to preheat, it beeps says that it is preheated but heats at about 100 degrees less than what I have set it for. This just started.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler work but oven wont go passed 100 degrees
heatman101
Jan 19, 2011 | GE Ovens
Oven wount go above 100 degrees or get hot
heatman101
Jan 11, 2011 | Ovens
It turns on but won't heat past 100 degrees.
heatman101
Sep 26, 2010 | GE Profile JS968 Electric Kitchen Range
Both upper and lower oven elements won't heat beyond warm (100 degrees) Jenn-Air Model# SVD48600P
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 15, 2010 | Ovens
Maytag oven mer577oaw won't heat above 105 degrees
Your thermostat/sensor has failed
CLICK HERE to see/order the part.
it is #5 in THIS EXPANDED DIAGRAM
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Ovens
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Not heating up
Hi.
I suspect you may have a faulty oven element, which is breaking down as it gets hotter, disconnect element and try if ,if it does not trip, then element is faulty
Nov 20, 2008 | AEG U7101-4 Electric Double Oven
Kitchen Ranges Logo
27 people viewed this question
Top Five Star Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ray gallant
Are you a Five Star Kitchen Range Expert? Answer questions, earn points and help others
