Factory reset for Panasonic BMP-BD PLAYER
Will not play blurry; gives Set 2 on display
5 Suggested Answers
Bluehound
  • 25 Answers
SOURCE: Philips DVD622 Factory reset
Go to http://www.philips.com and search for your modal then look in Q/A's or just look in the manual for the factory reset....Usually found in the on-screen menu!
Posted on Jan 11, 2008
  • 4234 Answers
SOURCE: Why wont the Samsung BD
Go to the Samsung website and get the latest firmware upgrade. That should resolve the problem.
Dan
Posted on Apr 16, 2008
SOURCE: Incompatible Disc in Sharp BD-HP21X Blu-Ray Disc Player
I had the exact same problem as you did... I bought the Sharp Aquos 42D85X which came with Sharp BD-HP21X Blu-ray Disc player. could not get brand new blu-ray movies to play and i found it froze everytime after 10 secs. I phoned sharp who basically were no help watsoever! I then went and returned my blu-ray movies back to the store thinking it was a problem with the discs.. The people there were extremely nice and since they had a display model of the BD-HP21X instore they offered to test the movie on it to veroify whether it was the blu-ray player was the problem or not. Turns out its a fault with all of the BD-HP21X models. So we then ended up returning it back to the store we bought it and exchanged it with the older model (BD-HP20X). I now have no problems playing blu-ray movies. Although another suggestion is to perhaps download the lastest firmware update & see if that resolves your issues.
Posted on Mar 16, 2009
  • 6771 Answers
SOURCE: Panasonic DVD player dvd cv37 won't play discs.
The problem is in the laser pickup assembly, over time the laser becomes weak until it can no longer play the disc. Buy a DVD cleaning kit and follow instructions, this may give more life to the player, if no change! it is far cheaper to replace than to repair.
Posted on Mar 20, 2012
My player wont load rented blu rays. I have cleaned the lens, done all the unplugging and replugging, and i have loaded older blu ray disks successfully. going to try a hard reset now.
hi donald.
this is all i could find at the mo,so not sure if this will help you out.if not go to the link and the bottom of this page might help you as well.
Blu-ray disc won't play on Blu-ray player [ Edited ]
Options ‎03-01-2013 09:34 AM - edited ‎04-08-2013 05:42 AM
If you are having problems playing a blu-ray disc is your blu-ray player, try the following.
1) Check the firmware-make sure you have the latest version. If your BD player uses the Xross media bar, following these steps:
Press the Home button.
Select setup
Select System Settings
Press the Enter button on the remote.
Scroll down and select System Information and press enter.
The Firmware version will appear on the screen. Write this number down and go to esupport.sony.com to see if you have the latest version. Just follow the instruction to perform the update. Check out this video.....it will walk you thru the steps I just described.
http://www.youtube.com/watch?v=0lI2IaK3XkA
2) If your BD player doesn't have internet connection, you can check the firmware version by:
Press the System Menu button.
Highlight Setup and press the ENTER button.
Highlight Video Setup press the ENTER button
Highlight TV Type and press the ENTER button
On the remote, press the Blue button
The current firmware version of the player will display. Write this number down and go to esupport.sony.com to see if you have the latest version. Just follow the instruction to perform the update. Check out this video.....it will walk you thru the steps I just described.
http://www.youtube.com/watch?v=kOq-zba_-5c
3) Some BD players requre that a USB memory device is inserted in the EXT slot of the player prior to playing the movie. It's recommended to use at least 1GB. If you already are using one and run into a disc not playing, try removing the USB device and plugging it back in.
Here's a few more things you can try.
1. Reset the BD Player:
  • Remove the disc from the BD player.
  • Turn off the BD player.
  • Unplug the power cord of the BD player from the electrical outlet.
  • Let the player remain without power for one minute.
  • Plug the power cord back into the electrical outlet.
  • Turn on the BD player.
  • Insert the disc into the BD player
2. Make sure that the Parental Control settings are not set to "On".
3. If the BD player supports the BD-Live feature, set the BD Internet Connection setting to "Do Not Allow" and delete any conflicting BD-Live date from the BD/DVD Viewing Settings menu.
won load rented blu rays Google Search
Nov 03, 2017 | Televison & Video
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
Panasonic DMP-BD871 display frozen
The instruction for resetting to factory defaults can be found on page 27 in the manual, which can be viewed here:
http://service.us.panasonic.com/OPERMANPDF/DMPBD871-MUL.PDF
Jan 23, 2014 | Panasonic DMP-BD871 Blu-ray Player with...
Every time i push a button on my remote for my sharp bd-hp22 blu ray player rc2 shows up on the display and nouthing happens
Hello
If reset option did not make all the functions revert to its factory settings, there may be some fault with its firmware. the firmware update should be done. But before that, insert a dvd disk [not Blu_Ray disc] in and see whether the set reads it an starts to play. If not, just open the top cover of the set, and look whether the disc inserted spins inside it as we power ON the set. If it does not spins, the sled motor should be checked. If disc doe not spin inside any disc player, the fault you points out here will occur. Just check this, and inform me. OK
Dec 12, 2011 | Sharp BD-HP24U Blu-Ray Player
How do I reset a Samsung blu ray DVD player bd p1600 model
Resetting Your Player To Factory Settings
Follow the steps below to reset your player. Resetting the player reverts all settings back to factory default meaning the network settings must be reconfigured after the reset is performed.
  1. Turn on your player and remove any discs wait until the front display reads No Disc
  2. Hold down the FF button on your BD player not your remote until the front display reads Reset about 8 sec and the player turns off.
  3. Press the power button to turn your player on. The Menu language selection screen appears, using the number buttons on your Blu ray remote select your language
The e-contents menu is displayed. Your player has been successfully reset. You will now have to reconfigure your network settings before you can launch any streaming services such as Netflix Pandora Blockbuster etc. If you need step by instructions click here to go to the Network Setup And Usage troubleshooting guide.
Nov 10, 2011 | Samsung Televison & Video
When eject is pressed, display says locked!
cant open or close dvd player.says locked.can use remote to play etc but cant open to change dvd
Mar 08, 2011 | Panasonic SC-BT200 Home Theater Systems....
Would like unlock code to play regions 1-6 on my panasonic sc-bt207
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay__g6
Dec 11, 2010 | Panasonic SC-BT200 Home Theater Systems....
Panasonic dvd-s54 unlock code to make it play region-free
Regards, Jay__uji8
Dec 27, 2009 | Panasonic DVD-S54 DVD Player
Region 1 DVDs will not play on my recently purchased panasonic blu ray. is there any input code to allow play
Regards, Jay__okp9
Dec 01, 2009 | Panasonic SC-BT200 Home Theater Systems....
Dec 25, 2008 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
