Question about Kenmore 74602 Gas Dryer
My gas dryer isn't producing any heat. If there is a service technician on kine now, can someone assist me with what they think it might be?? It starts and goes the while time, just doesn't dry the clothing
    Brigadier General:
  • 8,619 Answers
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
Dryer is not producing heat
Good Morning friend, thanks for your inquiry!
I understand that your Frigidaire dryer is not producing heat. Have you checked the exhaust vent to assure there is not a build-up of lint blocking ventilation? If so clean out the lint and check to see if your appliance heats after that. It could also be a potential issue with your element or thermostat I would suggest seeking assistance from a technician for further diagnose. I hope this information helps. -Matt
Sep 28, 2014 | Frigidaire Dryers
The dryer isn't drying. The dryer is a kitchen aid the model is kgye777bwh2. Also this is a gas model. I noticed that the pilot isn't lighting when I turn on the dryer. With the dryer running i...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 22, 2011 | Dryers
Dryer everything works, but no heat.
You didn't mention whether it was a gas or electric dryer, but either way it probably just isn't producing heat. If it's electric, it's most likely a defective heating element. If it's gas, the burner probably isn't igniting. On both there is usually some sort of thermal shut off switch that can also go bad and shut off the heat element or the burner.
Jul 15, 2011 | Dryers
I have a whirlpool lgq8611pw2 gas dryer. it has stopped producing heat. gas supply seems fine and other gas appliances work fine. Took front lower cover off and blew out dust> pulled and replaced...
go to this site..
I think the first item is what is bad. here's where to start.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-5-654402-/new/Whirlpool-Dryer-not-heating-LGQ8611PW2
Jan 07, 2018 | Whirlpool WGD5200TQ Gas Dryer
My gas dryer stopped producing heat produce heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Maytag Atlantis MDE7400A Gas Dryer
Frigidaire gas dryer, gallery series model GLGQ2152ESO - no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Jul 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Maytag MDG4000BWW gas dryer does not heat up
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch. The links below are listed in order of failure commonality.
1.Gas Valve Coils
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3479&PartID=3479
2. Ignitor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3018&PartID=3018
3.Thermal Fuse
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di516650&PartID=516650
These are only the most common parts that tend to fail. There are numerous other components that could cause the same symptoms. If the above assistance does not resolve your issue, you may request assistance with an on-line technician, or you can order a service manual from www.repairclinic.com
Aug 30, 2009 | Maytag MDG3600BW Gas Dryer
Gas Dryer won't produce heat
Hi, thanks for the inquiry.
It's most likely a thermal fuse. Basically, the voltage has to go through the fuse before it goes to the ignitor.
It should only cost you about $90 to repair if a technician comes out to fix a fuse.
I wouldn't try to repair it unless you have some knowledge of electrics. If your dryer is less than 12 years old, I would recommend you fix it. Hope this helps.
Best of luck :)
Aug 25, 2009 | Whirlpool Dryers
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
Gas Dryer with no heat or timer
Check the following
http://www.youtube.com/watch?v=rQV-z4f7fvA
If you need more assistance don't hesitate , e-mail us back.
Thank you Was this helpful ?
May 13, 2009 | Whirlpool Dryers
Kenmore 74602 Gas Dryer Logo
115 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
