Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
The power light comes on, then the tv just turns itself right back off
I looked in the tv...and i seen a few green lights inside...and one in particular blinks and makes a ticking sound as it does, it is the light that has the numbers d940, and d967 beside it
SOURCE: TV makes chirping sound and power button blinks, T.V. does not turn on
It is the lamp, you have to change the lamp, it's in the left side of the tv, have a litter compartiment, opened and take out two screw and take out the change and change it. you have to buy a new one. go to google.com and put the model of the tv and find the price of the lamp.
Posted on Jun 25, 2008
  • 150 Answers
SOURCE: No Picture no sound on a Hitachi Rear Projection
if the 120v never comes up, check e994 as it is probably open, and either the blue horizontal retrace cap infront of the h-out transistor is burnt/shorted or transistor could be.
Posted on Aug 05, 2007
ctf1800
  • 4402 Answers
SOURCE: Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
SOURCE: Hitachi 60v500a projection turns itself off
i have the same problem, did you ever get an answer?
Posted on Jul 01, 2009
  • 668 Answers
SOURCE: 57F500A, powered light on with no sound/picture, ticking noise
Over the years of servicing these sets and others for Convergence issues, I have on several times gotten defective Convergence ICs. In your case where a Resistor is now open, (Probably a 1.5 ohm 1/2 watt), I would suspect you had gotten a hold of a defective IC. I would replace them both again. Make sure to use Heat Sink Compound between the ICs and Heat Sink.(Just a thin coating on the metal area) You can get the heat sink compound from Radio Shack. They should also have the Resistor you need.
Good luck,
Skyassoc
Posted on Jul 25, 2009
Tv cycles on and off
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Jun 09, 2007 | Panasonic PT-52DL52 52" Rear Projection...
Today the TV just turned off by itself. I
Its your STK ICS STK 392-110s are Factory ICs use STK392-150s Call Mats 1-800-628-1118
Dec 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Sep 09, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Mar 27, 2008 | Televison & Video
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
