Question about Gateway LX6810-01 PC Desktop
One memory works on my gateway Lx6801
I had remove all the memories and only one works, I had put all 4 memories adding to 8gb and computer wont turn on, only fan
  • 70 Answers
Hi
the one working stick of memory needs to be put into the first memory bank.these are normally 2 coloured different to the other 2.make sure they are securely in place. plastic clips lock into memory stick.once done while power lead is removed turn on at tower.this will clear memory.plug back in and give it a try,if ok add another stick of memory although you said the other three sticks don't work give it a try they may work and save you a fortune.
Posted on Apr 22, 2014
  • Marco Rivera
    Marco Rivera Apr 22, 2014
    thanks, i added one at the time, and it work
melnavz
  • 1226 Answers
SOURCE: gateway sb-4100-b won't recognize new memory
REmove all the old memory and replace it by a new memory, you should test memory 1 by 1 .
first install the 1 memory in the first slot. then boot the computer using only 512mb. if this successful. shutdown and insert the second memory, then test again.
note: memory should be:
1. DDR SDRAM
2. the two 512 should be the same brand.
Posted on Dec 28, 2007
  • 55 Answers
SOURCE: Gateway 831GM Video card
The 831 only supports 2 gigs of ram any more and it wont start. You can probably fit a 9800 in it but would be a very tight fit.
Posted on Nov 30, 2008
rabins
  • 59 Answers
SOURCE: Gateway GT4016 not booting up. Fan works, but no
you may get some ideas from http://www.computing.net/answers/cpus/computer-not-booting-up/8457.html
Posted on Jun 25, 2009
  • 8404 Answers
SOURCE: Windows XP Virtual Memory is low. How can I regain memory?
Virtual memory is "memory" on your hard drive, not actual memory. The best way to regain this is reboot and shut down some of the stuff that runs automatically when you DO boot up.
(This Virtual memory is space set aside on your hard drive that the processor moves data into and out of like it would put data on a memory module ... but in comparing the two, the virtual memory is SLOW.)
You can increase the size of your virtual memory to anything you want. Some say too large a allocation will slow you down and too little will cause crashing or slow opertion. You are 99.44% probably set to let Windows manage your virtual memory (default) at this time.
thanks for posting your question to FixYa.com
positive comments are welcome
a
Posted on Nov 02, 2009
Biggdex35
  • 333 Answers
SOURCE: Gateway mfatxstl elp 500c. MEMORY PROBLEM
Check all of the other connections all around where you was at. Sometimes it dont take much to knock one of them loose. Also take the chip backn out and take a pencil eraser and clean the contacts on the chip with it.
Posted on May 24, 2010
Why won't it use added memory for downloads?
have you tried formatting the memory or seeing if the tablet recognizes it???? thats where i would start:)
Aug 16, 2015 | Hipstreet Flare 2 9 inch Tablet with 8GB...
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
I installed 5G memory cards to my Gateway GT5238 PC, 1024 MB DDR2, Intel core 2 Duo E6300, 9-in-1 memory card reader, Non EEC, 4 slots, max memory 8192MB (8GB), PC2-6400, 8500, 5300, RAM DDR2. It had 1G to...
  • You Gateway only supports up to 8 GB. memory. Hence it will not see your 5 GB. dimms
  • tops: 8129 MB (8 GB.). 4- 2GB. Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
  • Specs:
  • Installed: 1024 MB DDR2 (PC4200), 533 MHz memory (two 512 MB modules)
  • Expandable to: 8 GB (4 memory slots)
  • How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
    Thanks, Joe
    Dec 02, 2010 | Gateway Computers & Internet
    I ADDED NEW MEMORY AND THE COMPUTER WONT BOOT I JUST KEEPS RESETING AND DOING THE SAME THINGHOW CAN I FIX THIS.
    There are several things that could be wrong here: 1. You didnt install the memory correctly, open it back up and remove the memory sticks and reinstall them 2. Try putting only one memory stick at a time, maybe one memory slot is bad. 3. One of your memory sticks could be defective 4. You got the wrong memory sticks for your computer and they are incompatible with your pc, contact your computer manufacture to find out the exact memory sticks you need.
    Please leave me a good rating.
    Sep 04, 2010 | E-Machines eMachines Desktop PC
    My computer need to install more memory what i need to do
    First you need to check your owner's manual or online at the Gateway site to find out how much memory your computer can hold and what type.
    Then you need to see how many memory slots you have. You can then go out and buy the memory you need and remove the old and put in the new.
    You may just be able to add memory if there are empty slots--otherwise, you'll have to remove the old smaller memory sticks and replace them with larger ones.
    Jul 19, 2010 | Gateway Computers & Internet
    Trying to put new hard drive.when it starts up it beeps 3 times and no picture on the monitor.is the power supply bad? originaly the hard drive crashed and the trying to reinstall it kept coming up error...
    3 short beeps is a base 64K RAM failure
    Remove added memory
    If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
    • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
    Open computer and reseat memory
    Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
    Swap memory location
    If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
    If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
    Try another computers memory
    If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
    If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
    Replace memory
    If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
    • Information about installing and adding new hardware including memory can be found on document CHADD.
    Jan 31, 2010 | Gateway Computers & Internet
    Computer does not boot up
    Computer has three short beeps as it starts? computer RAM (memory) related issue.
    Hope this helps.
    Oct 22, 2009 | Gateway GT5404 PC Desktop
    Motherboard beeps three times, computer won't boot up
    Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
    Jun 13, 2009 | Gateway 506GR PC Desktop
    Adding Memory to Gateway 420r
    If you mean a Gateway 420GR (there's no "420R" listed on their site), then you can have up to 4GB of RAM and you can use 1GB modules. Here's a link to the specs page on their site:
    http://support.gateway.com/s/PC/R/4053/4053sp3.shtml
    Nov 21, 2008 | Gateway (4000779) Motherboard
    My computer crashes now and then... Tends to happen alot when im playing a pc game? It makes this loud screeching noise when it freezes i am forced to shutdown manually
    Your Memory card is the problem.
    Try this steps:
    1. Remove added memory
    2. Open computer and reseat memory
    3. Swap memory location
    If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
    4.Try another computers memory
    If you have access to another computer that uses the same type of memory try using its known good memory in your computer. If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
    Aug 25, 2008 | Computers & Internet
    Gateway LX6810-01 PC Desktop Logo
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
