Question about Fisher and Paykel DG05 Gas Dryer
Is there a way to test motor
Replace the capacitor but drum still does not turn
    New Friend:
    Problem Solver:
  • 11 Answers
Is the problem motor not running, or drum not turning? The motor itself is very quiet. Do you have a broken belt? If no motor running, check door switch or start switch. Smell motor. Does it smell burnt?Are the windings copper colored or
Posted on Apr 23, 2014
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
My Maytag Performa Dryer model PDET920AYW will heat but drum will not turn. Belt is not broken. Can you help?
It is possible that the motor start/run capacitor has failed, rendering the motor unable to get going. The capacitor will look something like this
http://como-reparar.com/guides/tumble-dryer-turning-find-fault-replace-motor-capacitor/
Jun 16, 2015 | Maytag Dryers
Dryer wont start turning, I can turn the drum and it will start
It sounds like the device that starts the motor has died. Now you have to find out if you have a capacitor start motor, or one of the induction start types. If it's induction type, the motor will need to be replaced. If it has the capacitive starter, you may only need to replace the capacitor. This type has a large cylindrical cap, located in in a can that resembles a black quonset hut. Some small electrical repair shops will test your motor, if you bring it in, for a minimal charge, or possibly gratis.
Oct 13, 2014 | Hotpoint Dryers
Drum trying but not turning when switched on.
Make sure the motor is getting full voltage, it sounds like only half is getting through. Also check the capacitor.
Nov 29, 2013 | AEG t35850 7kg vented tumble electric...
Oscillator is not rotating
make this test and fix it. God bless you
Belt
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt , and often the idler pulley, because the pulley tends to wear out at the same time. . If you hear the motor running but it does not tumble it is most likely the belt.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out.
Remove the belt.
Check for obstructions in the blower fan housing.
Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Check our videos on testing a motor and capacitor.
Door switch
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity. When Door is open no continuity when closed you should have a reading. If it's defective, you need to replace it.
Jul 30, 2013 | Dryers
My whirlpool duet electric dryer electrical systems and heat work fine, but drum won't turn and belt is in tact.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
Also check weather the timer is perfecty.
Sep 29, 2012 | Whirlpool Duet High Efficiency Electric...
Motor hums, but does not turn, 220vac at terminals
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 30, 2010 | Dryers
Dryer motor just hums, doesn't spin, kenmore front loading dryer
Try turning the drum by hand with the unit turned off. If it seems fairly easy to turn, then check the motor to see if it has a capacitor (about 2 to 3 inches long and 1 inch in diameter with two connections).This capacitor is used by the motor for starting. Replace the capacitor. If the drum is very hard to turn, something may be jamming the drum or the motor bearings may be frozen (new motor). Hope this helps.
Sep 26, 2009 | Dryers
Is it the capacitor or the motor that isn't working?
it's the motor to weak to jurn over,i see it all the time,replace the motor if you want(ebay)the model number is inside the door-mike
Jun 16, 2009 | Dryers
The drum on my dryer stopped turning it was heating and it just stopped turning, I just want to get instuctions on how to take it apart.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Jun 15, 2008 | Magic Chef Dryers
Fisher and Paykel DG05 Gas Dryer Logo
43 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
