Question about Vehicle Parts & Accessories
Need location of fuse box on 1990 Acura Legend and location of fan motor relay
Online manual says fuse box is under dash or near driver's feet. (I only know about the one on top of engine, driver's side). I have looked everywhere for it. VIN JH4KA4651LCO43098 First Generation. No power going to front power windows (but they do work when I take wire and run power to them). Fan motor on all the time too so I need to know where the relay is for the fan motor.
    Scholar:
  • 101 Answers
Many cars have multiple fuse box location. Most likely if there is one near the drivers foot it will be the left kick panel. There should be a door with a plastic tab to access it. The fan motor relay is most likely in the engine compartment fuse box as its much bigger than a fuse. If there is no access panel on the driver side kick panel then it would be mounted to the bottom of the dash with probably a black cover over it. there should be tabs on the side to open the cover.
Posted on Apr 22, 2014
How do I change wiper motor fuse 1992 Acura Legend
In the under-dash fuse/relay box, check the condition of 7.5A FUSE 23 and 30A FUSE 26. Replace as necessary.
Dec 15, 2016 | 1992 Acura Legend
How do I remove the starter on my 1993 Acura Legend?
Hi Gayle,here's a Autozone repair guide on replacing your starter,once off,have Autozone test it to see if it's bad,they will need it on a trade in,core.They test it for free,take's only a few minutes. SAVE 20 GET 10 GIFT CARD ON ONLINE SHIP TO HOME ORDERS OF 100 OR MORE Also here's something else to look at.
Starter Cutoff Relay
1993 Acura Legend 3.2L FI 6cyl
The Starter Cutoff Relay is located: Front seating area, driver side, under dash, mounted in fuse block.
Jul 28, 2015 | 1993 Acura Legend
Fuel pump fuse location 1992 acura legend
fuel pump fuse is located under the dash on the driver's side. Look for THIS -
The fuel pump relay is located underneath the dash, driver's side, up behind the metal panel (behind the plastic kick panel). It is NOT plugged into the fuse panel.
See #18 in this diagram -
Feb 20, 2014 | 1992 Acura Integra Hatchback
Starter relay location
The starter relay should be located in the fuse panel which is either by the driver's feet under the dash, or it may be under the hood. Most fuse panels have a legend or diagram of what is plugged into it. If not, check your owner's manual.
Oct 01, 2013 | Ford E-150 Cars & Trucks
Fuse diagram for 1990 acura lengend ls the label is gone
try asking at the dealer or buy a haynes manual ,yes i know the haynes manuals are not very good but they should have a fuse wiring diagram .
Oct 29, 2011 | 1990 Acura Legend
1990 Acura Legend, location of main relay for fuel pump
looked it up online, looks like its in the underhood fuse box but couldn't get a good diagram that shows which relay number it is. the website i use is sort of dependent on the manufacturer, apparently acura did not feel like sharing that info. hope that helps
Jun 17, 2009 | 1993 Acura Legend
1995 acura legand fan relay location
there is a sub-fuse/relay box that sits directly in ft of UNDERHOOD FUSE/RELAY BOX(drivers side engine compartment.located in sub-fuse/relay box
May 07, 2009 | 1995 Acura Legend
1990 acura legend ls battery power drained by a relay near front
My 1st generation car is off to college, but it is usually for a device nearby the relay. Check the wires from the two radiator fans. You can swap the relay from the a/c fan until you get a new one.
Jan 14, 2009 | 1990 Acura Legend
Blower motor for a 1997 acura tl
one of 2 places either under the dash behind the glove box or under the hood on the passengerside. first i would check the fuse and or fan motor relay. these are located in the box under the hood or under the dash on the drivers side. also i would check the reostat which controls the fan speed this is located near the motor and is held in place by 2 screws and has 2 wires hooked to it. one more thing to check is to make sure the switch is still good
Aug 29, 2008 | 1997 Acura TL Series
Vehicle Parts & Accessories Logo
94 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
