Simpson eziset 750 agitator rotates one direction only
At the time the agitator should rotate in the opposite direction there is a small clunk and the agitator remains stationary
3 Suggested Answers
  • 17 Answers
SOURCE: when washing, my simpson encore 806 seems to only
IF YOU WANT *** CALL 01232142356436
Posted on Sep 07, 2009
  • 713 Answers
SOURCE: Simpson eziset 750. During the wash cycle, it does
Hi just read your posting.Depending on how old your machine is it could be a couple of reasons.1st thing I need to know is how old your machine is? Also when the machine should turn the opposite direction listen carefully and do you hear a hum from the motor when it should be turning in the opposite direction?Please reply with this additional information and I am sure I can help you .Looking forward to your reply.
Posted on Oct 14, 2010
Hi, we have Simpson top loading washing machine model number Esprit 550, the drum is not rotating and the spinning plastic rod in the centre of the drum is not spinning/rotating either
that is a direct drive
is the agitator (plastic rod )loose or sloppy
if you look down the inside of the agitator
do you see a nut at the base holding the agitator tight
if the timer is working
and water can pump in and out
that is good
bad
if you cant hear the motor click in
it will need to have the inspection cover taken off
for service or part replacement
May 20, 2016 | Simpson Washing Machines
I have a silk blouse caught under the agitator of my Simpson eziset 8.5kg top load washer. does the agitator come off?
They should come off though I am not sure of your machine, they are designed to be changed.
Mar 05, 2016 | Simpson Washing Machines
Where is the lint filter on a Simpson Eziset 950 top loader washer?
lint filters for simpons top loader is at the bottom of the center lift out piece in the agitator
just pull the lot up and the lint filter is a small pocket at the end of it
Dec 10, 2015 | Simpson Washing Machines
Why machine full and spin but do not agitate
Hi
The difference between Spin & Agitate is the mechanism underneath which is driven by the AC Motor & rubber Belt. Not sure of your model but I believe if the Motor Rotates in say Clockwise direction then the mechanism lets it Spin. If the motor rotates the opposite way then the mechanical mechanism selects Agitate (back & forth). AC Motors use a large start capacitor to kick it off in the preferred direction or rotation. Possibly replacement of a large Start Capacitor might be the answer. The other possibility is that a Solenoid pulls a lever to change the mechanism into agitate mode.
CAUTION: AC Voltages & water can kill.
Pull the plug out before putting hands in.
If your inclined to open up the back & have a look at whats happening then this may shed light on the problem.
Otherwise... take the machine to a washing machine repair business or pay a bit more and have him do a house call.
Be sure to advise Brand, Model and Fault description so he brings parts along.
Cheers OBJ
Dec 17, 2014 | Whirlpool Washing Machines
How to remove simpson agitator>
I am not familiar with a Simpson but the nut securing the agitator is
commonly accessed by removing the fabric softener receptacle
and then a plastic cover which sits directly over the nut. If the
agitator proves difficult to remove tap a block of wood against it
and rotate upward until it releases. I hope this works for you.
Regards,
Dennis
Aug 20, 2014 | Washing Machines
Motor locks up when the washer tries to spin opposite direction to agitate
When rotated on the opposite direction to agitate the main pulley below the drum releases the brake in order to spin, remove the pulley and lower plastic components and check condition, when they become worn the brake is not released properly hence no rotation.
Sep 06, 2013 | Admiral AAV7000A
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
GE 15119 instructions please. The dial just says "time now." How do you know when light go on and off? Need directions. Can't believe there are none!
Here the help you need to set timer.
Rotate dial until current time lines up with black triangle located in center of dial
The black pointer remains stationary when you rotate outer dial
Now the outer edge of dial has 48 plastic segments that lift up
776e6ad.jpgHere are some segments lifted up on GE15207 timer
As I recall, segments-up timer OFF, segments-down timer ON
If you need more assistance, answer back and I will help
Oct 24, 2010 | Hardware & Accessories
Simpson eziset 750. During the wash cycle, it does not agitate in both directions, it will only turn in one direction, then stop and pause like it wants to turn in the opposite dirction, then turns in...
Oct 14, 2010 | Washing Machines
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
