Question about Dell OptiPlex GX520 PC Desktop
CPU fan runs at high speed and won't boot
Dell OptiPlex CPU FAN is runing at high speed
  • chajackson Jun 20, 2009
    It never gets that far in the POST. Nothing seems to be overheating, CPU or HD, all connections are tight.
Check the power supply for problems.
My computer wouldn't run thru the post up, no beep codes, only the fan running on high. The power switch didn't shut the computer down, it needed to be turned off at the power supply, or unplugged.
I replaced the motherboard to no avail. Only after changing out the power supply did it work correctly.
My theory is that the power supply quit supplying power to the motherboard, but kept supplying 12 volts to the fan.
The good news is that power supplies are cheaper than motherboards and easier to replace.
Posted on Oct 24, 2009
  • 952 Answers
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Posted on Jun 20, 2009
    Scholar:
  • 142 Answers
Take your memory out and try turning it on. You should get a beep code. Put one memory stick back in and turn it on. If the fan still runs high try a different memory slot and if that does not work try a different memory stick.
My experience shows that their could be a memory problem.
Posted on Jun 12, 2013
Dell optiplex gx110 will not start
The power supply fan is running or the CPU fan?
Nov 01, 2012 | Dell Computers & Internet
My computer dell gx 620 desktop fan is running fast and it keeps on restarting and hanging especiall during heavy games and also videos and the fan is running fast
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Aug 30, 2011 | Dell OptiPlex GX620 PC Desktop
Why is my dell optiplex GX260 CPU fan is very fast ?
Usually the fan regulates its own speed (or rather the BIOS does) in relation to the current heat, you may have heat/environmental issues, or power issues. However I would first check to see that the fan speed isn't statically(permanently) set to a high speed. You can check this in the BIOS, as the machine starts up it will flash a small message ( For Setup or For Setup, something like that), hit the stated button to enter your BIOS, under 'Thermal' or 'Hardware' you should be able to find fan speed.
Aug 22, 2011 | Dell OptiPlex GX260 PC Desktop
I have dell optiplex gx280 computer.i am facing problem of CPU high fan speed when i turn on the PC.it goes to full noise like a jet fighter and nothing get appeared on the screen and fan continuously gone...
dells usually go full blast on power up then slow down to normal,sounds like fan is not responding to slow down signal i would try replacing fan, its got to be a dell fan
Jan 08, 2011 | Dell Optiplex GX280 (99301) Motherboard
My cpu fan speed is countinuely high guide me how to low the fan speed
The speed is determined by a cause ..and to make it worked like It used to , you have to eliminate the cause...It probably has a dirty heat dispenser ..and the cleaning will make it run smooth again ...but also check the bios settings for the fan ..For dell there are available more than one modes..and you can go to bios and see which way is set ..Select the quiet mode and save changes on exit
Sep 30, 2010 | Dell OptiPlex GX520 PC Desktop
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
Jul 30, 2009 | Dell Computers & Internet
Dell GX280 High Speed Fan and No Display.
i had same problem today and i tested my machine and solved the problem at last.
the problem is the thermal value that your mainboard sets for your cpu.
please replace the mb.
ps: before this process,i tried almost everything . cpu fan , memory , cpu , cables ,case ... everything. but the problem is on your mb.
Feb 04, 2009 | Dell OptiPlex GX280 PC Desktop
GX280 - is it the motherboard?
Go here and download this program.
http://www.download.com/SpeedFan/3000-2094_4-10067444.html
This program will control your fan speed based on your cpu temp. It's main use is to quiet fan noise.
Dec 15, 2008 | Dell Optiplex GX280 (99301) Motherboard
Dell OptiPlex GX520 PC Desktop Logo
2,812 people viewed this question
Alun Cox
