Question about Coffee Makers & Espresso Machines
Keurig diagram my keurig 866 just spits out a few drops of water. wont make a full cup. Why?
SOURCE: When I use or attempt to have the Keurig serve a
I had the same problem and my Keurig is only two months old. I read advice from another user and called Keurig this morning. They are replacing the unit for me within 3 to 10 days. All they asked for was the serial number, which is very easy to find. Good luck!
Posted on Mar 03, 2010
  • 40 Answers
SOURCE: the keurig spits water into
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
heatman101
  • 43501 Answers
SOURCE: my Keurig will not brew a full cup. half the water
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Feb 26, 2011
heatman101
  • 43501 Answers
SOURCE: My Keurig does not brew
heatman101
';][-0
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
The machine will not pump water to make cup of coffee. Cleaned needle area, powered on and off, nothing. The descale light has never come on in 3 years we have had machine. Can't even attempt to descale...
Step 1: Lift up the water reservoir and drop it back into place. There is a magnet that has to be in the right position and putting the reservoir back into place causes it to go back where it should be. This method has worked for me.
Step 3: It could be that your Keurig's water line is clogged. To flush out debris, run water through your brewer a few times without a K-Cup. I'd recommend this step if your Keurig is brewing some coffee, just not a full cup.
Step 4: Try turning the power on and off or try unplugging (for a long stretch if you can). When you turn the Keurig back on, be sure to give it plenty of warm-up time. This has also worked for me.
Step 5: It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned. Go here for instructions
Step 6: Turn off your brewer and use an unfolded paperclip to clean out the holes in the top needle.
Step 7: If you've given your Keurig a good spanking and it still won't behave, contact Keurig (866-901-BREW) for help.
Oct 04, 2013 | Keurig B60 Coffee Maker
My keurig wont brew even after I descaled it a few times....it runs the water through but as soon as I put a k-cup in it stops and nothing is in its ways
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 24, 2011 | Keurig Platinum B70 Coffee Maker
My keurig keeps spitting the water back into the water reservoir and not brewing a full cup. I have cleaned the needles and have not descaled. How do I fix it??
Hi, Place your finger over the tube going back to the tank and force the water through the needle...
heatman101
Sep 11, 2011 | Keurig B60 Coffee Maker
Just bought the B70 coffee maker, ran water thru it initially as instructed. When put in the first k-cup it brewed but just before the water finished it spurted and spewed a couple of times...dropping...
Sorry to read about your problem, I hope this helps you out.
i think you had a bad k cup
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Keurig B70 Coffee Maker
Made a cup of coffee this morning and at first only the small cup was lit up to be selected. I chose the large cup anyway and it made the coffee. When it was done I opened the lid to remove the k cup and...
Hello. Definitely call keurig at
1-866-901-BREW (2739) Representatives are available 7:00 am to 12:00 midnight EST, 7 days a week
This is unacceptable and should be fully covered under warranty. Joe
Mar 05, 2010 | Keurig B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
13 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
