Question about Electrolux Heating & Cooling
Kelvinator inverter. Power light flashes and beeps but unit working fine
2 Suggested Answers
  • 81 Answers
SOURCE: power led flashing on air conditioner
This generally indicates a fault with the unit. Have you tried cleaning the air filters inside the indoor unit. This may help. Otherwise call Kelvinator or LG as they have similar unit and ask for their help and if it can't be rectified call for service.
I take the time to answer your question, so please rate me.
Thankyou Mat
Posted on Aug 26, 2009
Testimonial: "I have cleaned the filters, but I really appreciate the time you took to answer my query and offer other advice - Thanks"
My Sukam Inverter is not working, even if the power is on, and its continuously beeping! so how can I direct the power, and so that the switches connected with inverter also works fine?
The first thing I would check is to make sure that the polarity is correct... IE: That you have red connected to positive and black to negative, assuming you're connecting it to a battery that is.
Many inverters will actually self-destruct if the polarity is backwards... But some of the better ones will beep instead.
May 25, 2016 | Inverter Electronics - Others
My kelvinator split sys turns on for about 5 min the 4 lights flash blows warm air have no manual
If the 4 lights are the indoor unit indicator lights, it is a fault code. Do some lights stay on or do all flash? What model is it? Kelvinator ( In Australia) are sourced from various OEM suppliers, different models will have different fault codes.
Mar 16, 2015 | Heating & Cooling
MY FIJITSU inverter is not working correctly, the timer light is flashing continuously and the timer lights flashes 5 times can anyone help pleawe
fujitsu is a good brand.
try one of these two things:
Turn the unit off then on again. After that press test button on remote control (rear side) and look how many times now operation and timer LED flashes. Note that. Then press MANUAL/AUTO button on indoor unit until you hear 3 beeps from buzzer. That will erase error memory.
Switch off and than on unit and see if indication repeat or it is gone. If it is gone, keep using your unit.
If it is repeated post your notes here.
OR+++++++++++++++++++++FOR OTHER MODELS
5 x Operation flash and a constant Timer flash indicates an outdoor unit control error. With this code flashing on the indoor unit, you need to point the remote at the unit and push the test run button. The flash pattern will change to a continuously flashing Operation light and a number of flashes of the timer light which gives more detail on what the error is.
To get the unit to try to restart you need to push and hold the manual/auto button on the indoor unit for a few seconds then reset the mains power supply but leave it off for a minute or so for the unit to power down completely. If you are going to try this make sure you make a note of any error codes first if you have to get someone out to look at it, it will help them a lot.
Jan 05, 2015 | Inverter Heating & Cooling
How do I fix or reset my inverter?
Low input voltage or current.
Bad input voltage sensor.
Test by connecting directly to battery (with jumpers or make an adapter). The wiring or connection to your power port (cigar lighter) may be bad.
If it works at the battery, it is the car wiring. If not, it will cost more than the 25 dollar price tag to have it repaired. Just replace it (tryhttp://search.harborfreight.com/cpisearch/web/search.do?keyword=inverter )
Aug 11, 2014 | Powerline 0900-73 Slimline Inverter
Inverter Error err flashing
Not sure about this unit - but I can tell you how I fixed 2 of my own Xantrex inverters.
I took them apart and found that they had replaceable fuses - 400w inverter had 1 fuse and the 3000w had 12 which were blown. Replaced and all worked fine afterwards.
Hope this helps a little and good luck.
Apr 08, 2014 | Mitsubishi Electronics - Others
Power led flashing on air conditioner
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
No power output from my vector 1000w inverter.
Buy a different brand of inverter. Yours has developed a short which the protection circuit is catching. It then tries a restart but fails all over again. Most likely o/p short which looks like an overload to the inverter.
Jan 30, 2009 | Electronics - Others
Sounds like a ground issue,Try this,Take the jumper cables and hook just the neg clamp tho the battery and the other end to the case of the inverter for a direct ground and see if that works..
Please rate this fixya
Jan 26, 2009 | Vector 1000w Power Inverter
Panasonic tvs-100 voice mail beeping and flashes red power light four times
I'm having an issue with the same unit. But the blinking light is NOT on my phone it's the power light to the actual unit in my server room. It will flash 4 times and then stop. Flash 4 times again... I have looked through the manual to see what 4x power light means and I have found nothing!
Jun 21, 2008 | Lands Phones
Heating & Cooling Logo
11 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
Steve F
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
