Question about HEWLETT-PACKARD CM1415fnw AllInOne Laser Printer
EFAX Can HPCM1415fnw do efax
How to fax through the internet
You need to hook a phone line to your computer of Fax printer. OR Use this, or similar, service: http://home.efax.com/s/r/efax-brand12?VID=33675&gclid=CJ-nxt6Fi7UCFRQcnAodAzoAHQ
Jan 28, 2013 | Microsoft Windows XP Home Edition
I just changed my laptop, on my old laptop i can send document directly to my efax mesanger like i was printer them, this time i cant find efax listed as one of my printers on my acer windows7. any body...
You need to install the software that makes your efax account look like a printer. This is probably supplied by the efax provider. Look at their web site for support or at least an FAQ page.
Oct 02, 2012 | j2 Global Communications eFax Messenger...
Efax mesanger not added to my printer
I think that I just answered this. Please don't submit a problem more than once. You may always add information to an existing problem and more information is almost always useful.
How do I change the setting in order to use fax on voip line?
Hi
The data transmitted during a voice call and a fax transmission are converted to digital pulses in the same way, so sending is not the problem. The problem is at the receiving end. A receiving fax device has to be set to pick up the call before the voice call device, as it is the prompt of the fax transmission signal that makes the receiving fax switch from send or idle to receive mode.
So, if you are faxing over the internet the intended recipient's setup is a complicating factor.
Since faxing to landline fax machines via VOIP would incur a charge, you might consider a cheaper software solution such as eFax (www.efax.com), which enables the receiver to receive the fax as a PDF document attached to an e-mail.
I hope this helps
Aug 26, 2011 | Ricoh AC104 All-In-One Laser Printer
Trouble transferring to another fax machine
error 330 is bad news the power supply needs repair. First press the data registration button scroll down to file settings and press set scroll down to transfer and press set depending what was programmed you can start new and program in the fax number to where its going and select which days and time when you want it transferred. When you are finished you must push the TRANSFER button underneath the one touch panel for this feature to take effect. It will say transfer on the display.
Mar 26, 2009 | Canon LaserClass 7000 Plain Paper Fax
Fax modem
The best solution is not to need a fax/modem. Send and receive faxes via internet.
This program was PC Magazines editors Choice:
http://home.efax.com/s/r/efax-brand9?VID=33675&gclid=CL_th9ybypYCFQOIFQod1iRdyg
This way you don't need a phone line/ tying up your phone line etc..
Oct 28, 2008 | D-Link DFM 562E (dfm-562e) Modem
Not able to send fax to an eFax number
I've had the same problem before. I don't know if it will solve your problem directly but I can offer a work around or two.
1. I have an efax number but with a company called callwave.com , I fax stuff to other customers using callwave and my MFC 7820n completes each fax successfully. So if you can get yourself a callwave efax number you can fax to yourself and forward fax as an email to your intended party.
2. Or, you can use your mfc 7820n to scan your fax docs as a pdf directly to your computer and then emailing them to your intended party.
Unfortunately it might be a brother issue because at the office when I use the hp fax machine instead of the brother machine, the hp faxes to efax numbers without a problem.
Sep 05, 2008 | Brother MFC-7820N Printer
Fax software
Good software, but not quite free!
MightyFAX has a 30-Day Free Trial, after that $19.95, with free updates for life. http://rkssoftware.com/mightyfax/overview.html
eFax Messenger $19.95
http://www.efax.com/en/efax/twa/productOverview
Jul 19, 2008 | Computers & Internet
Compatability with efax
Try Brother customer service 1-800-284-4329 (usa voice #), but be prepared to answer a few questions 1st. The manual mentions nothing about eFax.
Jan 28, 2008 | Brother IntelliFAX 4100 Laser Fax
HEWLETT-PACKARD CM1415fnw AllInOne Laser Printer Logo
20 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
