Question about AR Blue Clean AR383 - Pressure Washer
Cannot release the high pressure hose from the spraygun, even when I press the button on the unde
I have the arblueclean model ar383l
No pressure once trigger is squeezed
We will have to just guess what this trigger is on :>)
AR Blue Clean - Spray Gun Trigger Squeezed, No Water Pressure
https://www.arblueclean.com/.../ar-blue-clean-spray-gun-trigger-squeezed-no-water-p...
When the spray gun trigger is squeezed, water comes out but there is no pressure. ... The RED color must stay in the window once the button is released.
pressure washer won't start unless trigger is depressed - Shop Your Way
https://www.shopyourway.com/questions/1151701 Jan 11, 2012 - pressure washer won't start unless trigger is depressed ... Thank you for your question on the pressure not starting unless you have the trigger pulled. ... After about 4 or 5 pulls the pump has built up enough pressure to make it ...
Pressure Washer Troubleshooting In-depth Beginner's Guide
pressurewashr.com/pressure-washer-troubleshooting/ Jul 5, 2017 - After holding the trigger to keep the water running through the machine ... (but not water supply) and release pressure by squeezing trigger gun.
Nov 21, 2017 | Garden
What is pressure in high pressure line for power stearing
Their are two (2) lines coming out of the back side of the pump, one of them will have a hose type clamp on it and be a bit big around than the other, that one is NOT the high pressure line. it is the return line.
Jul 04, 2015 | 2001 Dodge Caravan
Fix or Replace an old Campbell Hausfeld Air Compressor model MT30002
Usually, hot air indicates leaking valves or gasket within the pump or overworking (duty cycle). Most likely parts are not available but would be interesting to open the pump and examine parts. May just need cleaning/removing or carbon deposits, cracked reed valve or worn seat. Easy to repair. Remove the head very carefully marking all parts for easy re-install. Make gaskets using auto style gasket material of same thickness. Make any broken reed valves out of feeler gauge material of similar thickness. Any compressor can be made to work tankless but why not have a tank to store a bit of extra air and allow the air to cool a bit and drop out the water into the tank rather than just push it straight thru to the sprayer. Tankless compressor are mostly used for sprayguns or other tools that allow the air to pass thru so that the compressor will not load and heat up. That could be one reason that your compessor is getting hot. You spraygun should be allowing the extra air to pass thru and not load the compressor. Try adjusting the pressure setting on the compressor to the lowest setting allowing most of the air to bypass, then slowly turn up the pressure till spray gun just works as needed. If you are allowing the compressor to work at full pressure and only using say 25psi to paint, you are wasteing energy because the compressor cannot rest. On a tank type compressor, the compressor will rest when shut off pressure is reached. You can paint with tank or tankless, should be no difference, depends more on the spraygun. Good luck
Jun 10, 2012 | Air Tools & Compressors
Where is the reset button on the Comfortmaker AC-model number NAC048AKC3? Thank you!
if it is a split system that is permanently installed in your house the reset button will always be near the compressor so that means on the outside unit somewhere, you probably wont need to remove any screws to get to it. but before you press that button and think all is well, why did the reset button trip? answer> because it is a high pressure cut off. your unit probably reached over 350psi on the high side line or possibly even higher. that is not good. you may have a dirty condenser coil (outside) and you can just hose that out with a garden hose (pull the disconnect first). or you may have a rotting out coil if your unit is old or you live less than 5 miles from the ocean. Or you may have a bad condenser (outside) fan motor. check that out. if it overloads again after hitting the reset (which this unit may not even have, not all units have these just the higher end ones) well if it does overload again call a licensed ac guy trust me it will cost you less in the long run.
Oct 09, 2009 | Heating & Cooling
My Dayton siphon spraygun sputters.
there is an air leak at fluid tip; sucking air into fluid at some point.
Feb 27, 2009 | Air Tools & Compressors
Powermate pressure washer Model PW0872400
pressure washers has this pressure switches where in as you press on the trigger, the washer works and if you release it, the pressure would build up high and it would trip this switch to turn off the motor or deflect the water to the by pass hose ( if the motor is not stopping) then as you press again the trigger, water should come out of the gun again but would not,
i have encountered the problem is in the pressure switch, even the pressure went down, sometimes it wont close the contact then the motor wont run ,
if the motor is continously running, then the trigger switch is the problem, the pressure excerted on the switch is so high that even if you press it , it won't open up to release the water.
what i can suggest is to tie the trigger in the gun so that it is always pressed and then just unplug the unit if you want to stop using it. it is an inconvenience but it will work.
or, open the gun and see if you can figure out why pressing the trigger would not open the switch.
another option is you can lower the pressure of the washer if it has an adjustable pessure controller. by lowering the pressure might open the switch when ever you press the trigger.
i hopw i was able to fix...
good luck,
drcool
Aug 21, 2008 | Coleman (100076) Compact Refrigerator
AR Blue Clean AR383 - Pressure Washer Logo
Top AR Blue Clean Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an AR Blue Clean Garden Expert? Answer questions, earn points and help others
