Question about Makita 10" Compound Miter Saw LS1040
Where does spring fit - Makita 10" Compound Miter Saw LS1040
How to change rear suspension springs on Polaris snowmobile
when fitting springs in a suspension, the procedure is to fit the springs first and then assemble to the suspension units , axles and cross shafts with the suspension bolts.
Dec 17, 2014 | Cars & Trucks
Can I fit valve stem seals without taking the head off on 1600 sentra 1997
No you can't..
Fitting valve stem seals involves removing the valve springs. This means the valve has to be held in place by a valve spring compressor (bought from almost any spares outlet). The springs are compressed by placing one end of the compressor tool on the valve face and the other end over the spring cap, then squeezing the tool to compress the spring, then removing the split collets that hold the spring in place, removing the spring cap and spring, then eventually you have access to the stem seals.
The head has to be removed to accomplish all this.
Mar 28, 2014 | 1997 Nissan Sentra
Chain saw brake on husquvarna model 41
To replace the brake band do as follows, remove the bar nuts and take the brake away from the saw, engae the brake to remove as much tention off the internall spring by pushing the hand guard fully forward, remove the allen screw securing the hand guard, do not remove the e clip and pin from the hand guard, tap out the pivot collers and remove the hand guard, remove the cross head screws securing the spring cover, carefully remove the spring from under neath, tap out the silver pivot pin from the knee link activating arm, use a puch from the other side of the brake to remove the roll pin securing the other end of the band, with the band out remove the screw securing the band to the knee link, install the knee link to a new brake band, re fit the roll pin in the band and re fit into the cover, insert the spring, this will have to be compressed to get it back in, re fit the spring cover, you need now to load the brake, fit the hand guard onto the cover, insert a conical puch through the hand guard and cover to enable you to pivot the hand guard back and load the brake, now fit the hand guard properly onto the cover and re fit the collors and screws.
Jul 26, 2012 | Husqvarna Garden
How do I replace the pull start?
Remove the four screws securing the starter houseing, with the starter removed, pull the cord out, tuck the cord into the cut a way in the side of the pulley and allow the cord to wind in slowley to let the tention off the spring, make sure all the tention has gone, now remove the centre screw, take away the pulley centre and the round spring from behind, note the hole in the pulley and the centre hub for the spring location, now carefully remove the pulley, be aware there is a large spring behind, remove the knot in the end and remove the starter handle, fit the cord back into the new pulley, refit the pulley into the cover making sure to locate into the spring behind, thread the cord back through the cover and reconnect the handle, knot the cord, re fit the round spring back into the locating hole in the pulley, re fit the pulley hub making sure the spring fits into the hole in the hub, re fit the securing screw, now put the cord back into the cut a way in the side of the pulley, wind up the spring, allow it to pull the cord back into the starter, only wind it enough to pull the cord fully back into the cover, re fit the starter.
May 01, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Trying to put recoil back together, how does spring go
There is a groove where the entire plastic case around the spring will go. It will only fit one way. Be careful when installing the spring, if it gets lopsided. IE. Part of the spring sits on the groove for the spring housing and the rest of the spring housing fits into the the groove, the spring will come out of the spring housing.
Oct 20, 2010 | Stihl Concrete Cutoff Saw Rewind Recoil...
Im putting the left back shoes on and i dont know how the springs go back together could sumone tell me
Easiest would be to look at the right side wheel (assuming it's not been dismantled as yet) Take note of which spring goes where but also in which direction. ie if the long end of the spring is pointing to the front of the car on the RH side, then the same spring on the LH side of the car should also be pointing forward. The trick to shoe assembly is to put the springs on before you fit the shoes to the housing. Fit the first shoe to the parking brake cable, then fit it to the housing. Now attach the springs to the fitted shoe. Last connect the other shoe to the springs and pull the shoe into its seat.
Jul 14, 2010 | 1990 Oldsmobile Ninety Eight
Chevy express 1500 can 2500 coil springs fit or the leave spri
yes they will fit. be careful use all the suspension parts, life springs coils a-arms upper lowers its a all day projected get a coil spring compresser
Jan 29, 2010 | 2000 Chevrolet Express Cargo
My 2003 Z71 Suburban's rear springs are getting worn out. Is there anywhere I can go to get new springs other than the dealer? Would the front springs from an Express 2500 fit?
there are spring companies that have heavier springs, google chevy truck springs and see what comes up. I dont know about the 2500 springs, maybe??
Oct 01, 2009 | 2003 Chevrolet Suburban 1500
Trying to fit new door seal with spring keeper to washing machine
Fit the seal first and then fit the spring,it cannot be done with the spring fitted on the seal first.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Makita 10" Compound Miter Saw LS1040 Logo
61 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
