Question about Harley Davidson Lands Phones
On my harley fxrs 1991 it feels like its missing / stuttering when running at low rmp, I have replaced the coil and leads and spark plugs and pulled the ss carb apart to check jets if blocked, some times it runs ok and then its stutters
SOURCE: I have a 1984 Harley
coils can be tested dynamically with an oscilloscope which you probably do not have so your next best approach is a ohm meter. not knowing your coil will make it hard to suggest a reading but you can get the spec's from the manufacturer or web site. the primary side could be from one ohm to 3 to 5 typically, could be more depending on coil. you can also check the ohms on the secondary by probing the primary terminal and a secondary (plug wire hole) terminal. here you should have a few thousand ohms depending on coil. if you get no readings, then the coil is bad. by the way, if you are checking voltage as pyrhyc says, you will have 12 volts on both sides of the coil. why? most ignitions will open the ground side of the coil to make it fire because as the current is pulled down, the magnetic field will colapse inducing electrical current in the secondary thus firing the plug. one redneck check is to take a 12 volt battery and hook one wire to one primary terminal and drag the other wire across the other terminal (bike wires removed for test) and watch plugs, if you get fire, check module.
Posted on Aug 27, 2008
SOURCE: engine 2003 harley missing
could also be a crank position sensor if a late model bike. make sure power is not sporatic.(depends upon model) the power flows from ign sw. through a fuse or cicuit breaker (circuit breaker could have intermitant contact) then to handle bar sw. which could have the same problem, then to the bank angle sensor which could have the same problem and finally to the ign module. hey, pyrhyc, what is a jet seat? (what a fighter pilot sits in?) a jet is just an orfice, which i agree could wear but if it does, a rich mix will not miss. it will usually cause sooty plus or black smoke from the exhaust. if too rich, the bike will bog out and/or quit running. a lean mix will cause a misfire. if you are talking about the mix needle, it does not seat in the carb, it only controls the amount out fuel that slips though the main jet until wot. screaming chicken is a good module but i would not buy them when aftermarket is much better. unless it is strickly race, big brother still has his fingers in it and limits the full potential of the bike. higher revs are ok but there are other mods that need to be done before going there. the number one hold back is hd hydraulics. they are good for a stock setup only. there are cheap ways around this and then there are expensive ways are this.
Posted on Sep 07, 2008
  • 29 Answers
SOURCE: my 81 shovel sounds and feels like it is fouling the plugs.
The first thing I would look at is the accelerator pump in the carb. The original carburetor on your bike was a Kehin. The pump consists of a small cam, rod and diaphragm. Most likely the diaphragm has ruptured. Take the air cleaner off and at the bottom right of the carb there is a round boss the size of a quarter with a cast tube on top. Remove the 3 screws under the boss and a spring and the diapragm will fall out. Even if you don't see a hole, if the diaphragm is wet with fuel on the top, replace it. Hell, replace it anyway, it is not expensive. It is also possible the outlet plumbing is clogged. Spray some gumout through the discharge port (you will have to look at it from underneath to do this if the carb is still mounted) and it should exit at the little brass jet right in front of you. Make sure the tiny o-ring and the lip on the diaphragm are seated in their grooves when you reassemble it.
Posted on Dec 27, 2008
alicantecoli
  • 22156 Answers
SOURCE: 1981 Vanagon (air cooled) hot stutter
change the flexible feed pipe for the servo it runs off the inlet manifold left side to a metal pipe,if this goes porous then idle is rough brakes dont work right and as it get hot it will run like a demented old woman who smoke 80 a day
Posted on Jan 31, 2009
  • 9 Answers
SOURCE: 2005 yamaha yzf 250-unstable idle
I had the same problem, Turns out that my shims were finished, replace the chims and check clearences.
Posted on Mar 12, 2009
My 1991 chevy s10 2.5l want crank it's getting red spark
Hi Austin:
Counting on my fingers I make that over 25 years old, so the maintenance history and mileage become very relevant.
I'd be considering an ignition tune-up as an appropriate first step.
Changing spark plugs, plug lead harness (wires), rotor, cap, coil, Points & condenser (or solid state components.
Chances are it will show a remarkable improvement.
Jul 15, 2016 | Cars & Trucks
SPARK AND IGNITION SYSTEM ON A 1988 HARLEY DAVIDSON FXRS LOWRIDER
Hi William, this is an easy fix and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of over use of enrichner.
5. Vacuum hose to fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, loose or broken battery terminal connections especially the "NEGATIVE" cable at both ends.
8. Loose wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP CKP and/or BAS).
11. Sticky or damaged valve or pushrod wrong length.
12. Primary cam sprocket spline sheared or missing spacer.
13. Security alarm needs a reset.
For more information about your issue, please visit the websites below, and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Harley Davidson Manuals Mark Workshop
Aug 23, 2015 | Harley Davidson Motorcycles
Jeep engine troubleshooting
run fault codes and you will find that missing is also from faulty injectors, mechanical faults, low fuel pressure and not always spark plugs and leads
Dec 23, 2013 | Cars & Trucks
My 92 fxrs Harley turns over but won't
Hi Jasong1969, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Jan 22, 2012 | 1993 Harley Davidson FXR Super Glide
The engine stutters and feels like it will stall and has allready twice) it is a automatic
check for oil in the spark plug leads
check your coil for damage (cracks) replace if there is any
make sure your tune up is proper
Oct 13, 2009 | 1987 Honda Prelude
94 Buick Park Avenue that stutters under a light load
check for a loose harmonic balancer(big pulley on bottom of engine.
oil soak can damage this part too.
Aug 06, 2009 | 1994 Buick Park Avenue
I have a 1984 Harley Davidson FXRS. I have a single fire crane hi 4 ignition system. It ran flawlessly for a few years and now the bike missed a few time then quit entirely. Now have no spark and would...
There's no real way to check the coil, it either works or it doesn't. I've found that with my Harley's when I lose spark it's generally a bad wire or loose connection. If the wires/connections are good, then it's either the coil or the ignition module. I'd say with the newer Crane on it, that the problem is going to be with the coil. Check the voltage from the ignition module going into the coil. I'm not exact on the voltage, but as long as you have a good strong current getting to the coil, and low to nothing on the plug wire side, then the coil is bad.
Aug 03, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
16 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
