Where are the low side and high side freon ports on a 92 buick re
Where are the low side and high side freon ports on a buick regal, with a 3.1 engine located?
  • Randy Prevost
    Randy Prevost May 11, 2010
    Your question leads me to first ask more questions. Before you attempt to do any servicing on your A/C unit, first check your local city/state zoning regulations. Given that freon is involved and is deemed an ozone hazard, you could get yourself into a bit of trouble if you're not authorized to purchase and handle it. What is it that you are attempting to do? Recharge the unit or purge it?
    Sergeant:
  • 340 Answers
Auto stores will sell you what you need.follow the lines you will find the access. but you really need to know what your doing. pay somebody that knows it will be money saved if your sure it needs freon how do ya know . be careful. Tom
Posted on Jun 21, 2009
Where do you put freon in on a 2002 Buick Century?
There are 2 capped ports the low and high sides. The freon gauge set will only fit on one of the two ports. The low side. Run the ac attach the freon hose and add as necessary
I’m happy to help further over the phone at https://www.6ya.com/expert/david_66a56a0239b6ab32
Jul 28, 2015 | 2002 Buick Century
Picture of low side ac port on 2001 buick regal
You low pressure port is against the firewall just below the center of the cowl and is best accessed from the drivers side
Jun 30, 2012 | 2001 Buick Regal
On 2002 buick regal ac problems. Tried a jumper wire from the pressure switch on high side( smaller ac line ) . no switch on low side by accumalator. vOLTAGE THROUGH WIRES ON HIGH SIDE. NO VOLTAGE GOING TO...
Does the system have a leak? If it does, then the computer might have set a low freon code that usually does not turn on the check engine light by itself. If this occurs, the code will have to be erased before the compressor will run. The computer does this in order to protect the compressor so that it cannot run without enough freon in the system. Once you correct the amount of freon in the system (if it needs it), reset the system and see if the compressor will run. Some parts stores have the ability to erase codes and will usually do it for free. I hope this solves your problem. It's definitely not good to have AC problems this time of year. Thanks for trying Fixya.com.
Jun 29, 2011 | 2002 Buick Regal
Where is the low ac suction side located on a 1992 buick regal
First find the A/C compressor, it is attached directly to the engine and has a pulley on it. When you turn on/off the A/C while the engine is running you should be able to locate it by listening for it to engage.
When you find it you need to trace the two metal pipes that come out of it. One pipe is the high pressure side and one is the low. You will know which one is the low side when you find the 'tee' with a plastic cap (both high and low have one).
The fitting that comes with the A/C recharge kit will only fit properly on the low pressure port. Sometimes, but not always the low pressure port has a blue cap.
Jun 19, 2011 | 1992 Buick Regal
I need to know how to find the low port to add refrigerant to the AC on my 1998 Buick regal.
Follow the AC lines and look for a plastic cap. There are 2, The big one is the high side and the smaller one is the low side. Unscrew cap to add freon.
Aug 20, 2010 | 1998 Buick Regal
Where do i refill the ac - 1999 buick regal
yes thats the low side- if you have no freon in system you got a leak
Aug 29, 2009 | 1999 Buick Regal
Where are the low side and high side freon ports on a 92 buick regal with a 3.1 engine
high side is higher than low ,two different connections, screw off caps follow from compressor ,hope to help you,robert b.
Jun 20, 2009 | 1995 Chevrolet K1500
Location of low pressure air conditioning port?
Follow the biggest a/c line from start to finish.Usually the a/c port is located near the firewall.I have seen the port located under the passenger wheel well.There should be a decal that states the type freon on or near the fan shroud,core support or on the under side of the hood.It is most likely to be type r-12.You can purchase an r-134a conversion kit. If you are not a/c certified to use r-12,you do not need certification for r-134a.
Aug 26, 2008 | 1990 Buick Regal
A/C service ports
low side is on dryer;not in line
Jun 18, 2008 | 1991 Buick Regal
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
