Question about Sharp LC42SB45U 42 in. LCD TV
Sharp tv volume keeps going up
Volume increase by itself, turn it down and it goes back up.
SOURCE: tv volume
try to put it on menu and check if the volume has set up to the higher volume.i think somebody touch yhe settings of your television.
Posted on Oct 23, 2008
SOURCE: Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Posted on Jan 06, 2009
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Posted on Aug 17, 2009
  • 733 Answers
SOURCE: have a sharp aquos TV. Cannot get the volume very
If you have the tv signal coming from the cable box, then check the settings for your cable box. if not check your owners manual.
Posted on Feb 08, 2010
  • 8457 Answers
SOURCE: Volume won't display and can't enter menu
U can unplug.replug about an hour later,it will reset it back to factory setting.Should work as before.
Posted on Mar 06, 2010
Harman Kardon AVR 120 volume goes up all by itself. I turn it down, it goes up again. over and over ... then it stops doing it. Is it the optical cable? COMCAST?
After setting volume remove all remotes from the room. It is possible that a button is staying activated.
All in the setup of the TV if you are using the "net" option that allows for communication between devices on the HDMI connection turn off as a possibility.
Last resort is the volume control motor driven knob on receiver see if receiver is defective try with other inputs such as radio etc.
Disconnect all inputs and see if volume increases?
Hope this helps?
Nov 01, 2016 | Harman Kardon Audio Players & Recorders
Volume goes to 0 by itself
i am having the same issue, volume shoots down to zero for no reason and I can only use the digital display to increase the volume, the actuall volume controls do not work. can anybody help with this
Apr 03, 2014 | JVC Kwavx830 Car Video Player
Samsung TV Version CZ04 volume reduces itself and whenever goes back to normal
Your volume goes down or up depending on the demand (number of viewers} viewing the channel at any given moment. That is mormal.
Nov 28, 2012 | Televison & Video
Techwood tv volume going back down
I've got this problem these fixing only work for a sort time! Volume just turns itself down?! Anyone no the real fix?
Jul 03, 2012 | Televison & Video
LG TV 32H3300 - volume increasing and decreasing by itself. It will increase if it was turned up via remote last and then will decrease by itself when volume is decreased via remote because it was too...
The cause of the problem is that the switch of your tv is dirty when cleaning it you must be familiar to the unit and the parts you will remove to prevent any damage you can use a contact cleaner, when applying a contact cleaner you must only spray it to the switch. Consult a expert technician to do it for you actual.
May 15, 2011 | Televison & Video
Volume decreasing to zero by itself
Have you looked to see if the Button on the tv itself is stuck in. Press it and you might be able to feel for it sticking. If this is the case you may want to try a baby wipe or something similar to try and sort this out. (dont use a sopping wet cloth)
hope you get this sorted.
Little Dish Fitter.
Oct 07, 2009 | Toshiba 32A33 32" TV
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Controls
Someone push the volume up button too hard and is stuck,this also has the micro(brain) confused,all this happen before you fund out your remote would not work.
Sep 03, 2006 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sharp LC42SB45U 42 in. LCD TV Logo
56 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
