Question about Sprint PCS Vision A640 by Samsung(r) Cellular Phone
Keypad won't function
Same exact problem. when flip is opened, camera comes on. No keypad buttons function except for END to turn on and off.
told by tech support that I could not fix. they will send me a replacement phone for $100.00 because I don't have a protection plan.
since I have fulfilled 2 year contract, I'm better off getting new phone for free (or less than $100), but renewing contract.
debating on going with another carrier. not too crazy about sprint.
Just added my experience. no user fix. return phone to provider for replacement.
Posted on Jun 20, 2009
Doro PhoneEasy 410 some buttons won't work on keypad
It maybe a flex problem or keyboard problem. The reason why I said it maybe a flex problem is because flip phones are fond of having flex problems because of the constant open and close of the flip. It makes the flex wear/worn out.
And it maybe a mere disconnection.
Which ever the case maybe, the phone needs to be disassembled in order to check/know what's wrong.
Regards.
Jan 25, 2012 | Doro PhoneEasy 410 Cell Phone
I have a 3/4 hp model 139.53990D from sears. My reomtes have quit opening the door. they will close it. The light on the control console blinks very lightly, not like when the lock is set. Door works...
The symptoms you give are exactly the way it is when the lock function is used. The wall control and the keypad will work but not the hand remotes. If holding the lock button for 3 seconds doesn't change it you should hold in the smart/learn button for 6 seconds. This will erase all remotes from memory and only the wall control will work. Now program it for the remotes and the keypad.
Jan 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
How do I change the code on our liftmaster 1/3 H.P. gargage opener
To program the keyless entry, first locate the smart/learn button. On the chain drive models, this button is on the end farthest from the door. On the belt and screw drive models, it is on the right side as you face the door from the opener. You simply press and release the smart/learn button. You now have 30 seconds to enter your four digit PIN number into the keypad and hold the enter button for five seconds. Wait one minute and test the keyless entry by entering your four-digit PIN number and pressing enter.
With some Security+ models, you can also program your Model 940CB Wireless Keyless Entry without climbing a ladder, right from your Multi-Function Control Panel. Simply enter your pre-selected code and press and hold the enter button on your Keyless Entry. Then press and hold the light button and the pushbutton on your Multi-Function Control Panel. The garage door opener lights will flash to confirm that the Keyless Entry has been successfully programmed.
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate, and plug the garage door opener back in. The keypad should be programmed. You can find additional information at:
http://www.usdoorcontrol.com/kbase/liftmaster-main.html#14
Nov 12, 2009 | liftmaster Chamberlain Garage Door Opener...
Buttons not working.
try this strip ur phone complety and clean it with a old toothbrush, leave it for 15 mins and put it back 2 gether again
Jan 26, 2009 | Motorola Mobility V551
You have to take your phone into a sprint repair center, you cannot fix it manually.
Aug 04, 2008 | Sprint PCS Vision A640 by Samsung(r)...
Frozen buttons except red end call button
it seems you have the common v3 keypad flex problem - normal issue - it costs $25-40 to replace depending where you do it.
we charge $25 + shipping
http://horizonwirelessonline.com
Dec 25, 2007 | Motorola Mobility Razor Behind-the-Head...
Camera
Its designed so that the camera only works with the phone shut. There are no camera functions controlled by the keypad. For instance if your camera shield is closed and your phone is open if you then open the camera shield the phone will tell you to close the phone.
Nov 10, 2007 | Sony Ericsson S710a
This is a common problem, it has to do with the keypad flex. either the connector on the top part of your phone is unpluged or your flex is damaged. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to repair
Sep 22, 2007 | Motorola Mobility RAZR V3
Motorola ROKR e1 keypad problem
It's the problem with the keypad board, the hardware problem not software, clean the connector carefully and replace the keypad board with the new one. This will solve the problem. Regards.
Aug 23, 2007 | Motorola Mobility ROKR E1 Cellular Phone
Sprint PCS Vision A640 by Samsung(r) Cellular Phone Logo
85 people viewed this question
Top Sprint Cell Phones Experts
TekkiDave
 steve
steve
celticsel
celticsel
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
