Pin configuration of cca612 cable - Computers & Internet
I need the pin configuration of Battery detection cable for MGE UPS EX7RT
Here's a link to the manual.
An RJ 45 network connector will either be a crossover or a straight patch cable. http://www.mgemexico.com/pdf/EX_RT_manual.pdf
Mar 26, 2014 | MGE Computers & Internet
Where can i buy a data cable for my panasonic pv-gs80 that can config wiht my pc
Ask for IEEE1394 cable also called iLink or firewire.
Beaware that firewire has several types of socket configurations.
In most cases a 4 pin to 6 pin cable will work.
4 pin goes to the camera 6 or 9 pin goes to PC or Mac.
Al
Sep 14, 2013 | Panasonic PV-GS80 Mini DV Digital...
How can i setteled the front panal usb pin connect on the usb panal on motherboard gigabyte845 gvm-rz
There are 2 USB Ports for the Front Panel USB ie F_USB1 / F_USB2 beside the "PWR_LED". You can use either F_USB ports. Just plug in the USB cable pin accordingly in the Configuration below. Be sure the the negative & positve pins are correctly plug in or it might caused damage to you Mainboard. (Pins 9 &10 not used). For further reference you can download the manual @ Link
Pin No.- Configuration
1-Power 2-Power
3-USBDx- 4-USBDy-
5-USBDx+ 6-USBDy+
7-GND 8-GND
9-No pin 10-NC
Hope it helps.
Aug 06, 2011 | Gigabyte 8IG1000MK Motherboard
HOW TO PROGRAM LS4278 SCANNER TO CONNECT TO KEYBOARD CABLE CONNECTION
Hi, i want to connect mt LS4278 with micrologix directly using the 8 pin ps2 port.
so any body can give me the pin configuration for making the cable RJ45 to 8 round pin.
pankaj
Jan 31, 2011 | Symbol LS 4278 Barcode Scanner
I have an old Magellan Meridian XL that has the power cable missing and I cannot locate another cable. Anyone know the pin configuration so I can make up a cable ? Power only, no data in and out.
Hi yakabofski!
There are TWO configurations of the pins with these units. We have the FIVE-pin config and the assignments are as follows:
Top pin- 12v
Bottom pin- ground.
Hope this helps.
Apr 06, 2010 | Humminbird Fishing GPS Receiver
VGA problem with HP monitor
The VGA cable are standard pin out for VGA DB15HD connector.
Learn about it here: http://en.wikipedia.org/wiki/VGA_connector
Apr 02, 2010 | Computers & Internet
VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Jul 22, 2008 | Samsung 793S 17" CRT Monitor
Floppy Installation Problem
I think the cable is the other way around. The end which has a twisted portion and with or without pin 3 covered goes to the FDD while the other end with or without pin 5 covered goes to the motherboard. Pls refer to the image below.5303f10.jpg
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 30, 2008 | Acer Computers & Internet
FireWire i.Link which cable?
teedoff1980,
You can buy the FireWire kit at your local electronics store or department. Some kits come with a FireWire cable with USB connectors, as well as "ends" for that cable that come in both 4 and 6-pin configurations. Make sure you ask the store rep and read the package to ensure you have the right ends. You can also buy cables that are already appropriately "ended".
Most cables are 6 pin and connect to the 4 pin port (with a 4 pin end)
Hope this helps :)
Jan 06, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Computers & Internet Logo
204 people viewed this question
David Payne
David Payne
