Question about GE Washing Machines
Does not agitate or spin
GE Profile top loader WPRE6150KWT just delivered this morning fills OK does not agitate or spin drains but leavese small amout of water in bottom
    Scholar:
  • 71 Answers
Let me make sure I hear your symtoms right..
The washer fills...sound like the motor is running but it doesn't agitate or spin.. then when it tries to drain it bascially gravity feeds out until there is no longer enough water to force it out?
Sounds like the belt is off, or broken.. I am not all that familiar with your model, but I think most GE's are belt drive.
If it were the agitator coupler, the washer would probably still drain..
Pull the front cover off of the washer, you will see the belt and pulleys, make sure it is A: still on the pulleys, and B: tight.
If not, loosen the four bolts on the moter, put the belt on and then slide the motor towards the rear to tighten it.. then tighten the four bolts. They may simply have not tightened the bolts on the motor from factory and the motor slid back loosening the drive belt.
GOOD LUCK!!!
Posted on Jun 20, 2009
GE WASHING MACHINE NOT AGITATING OR SPIINNING. IT FILLS AND DRAINS. WHHAT COULD BE THE PROBLEM. ITS A TOP LOADER. MODEL WDSR2080D0WW
if you open the lid, you should see a white plastic rectangular piece on the front right corner. try taking a magnet ( stronger the better) and placing on top of the plastic piece. that plastic piece is part of your lid lock assy. sometimes the magnets inside that plastic piece will get stuck, and won't allow unit to start. If you wiggle the magnet around, if you listen real close, you will hear a light chirping sound. if you hear chirping, lid lock should be ok. If that checks ok, take a look at the motor at the bottom front of the tub. best way to access the motor is to use a putty knife to separate the front panel from the underneath of the top of the front lip. there is a LED light on top of the motor. It will blink a series of blinks if there is an issue that registered any error codes. There is a tech sheet located behind the control panel that tells what blinks mean. Hope this helps
Feb 26, 2015 | GE Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Washer will fill and drain but not agitate
Check the lid switch if it is a top loader.
Nov 04, 2009 | GE Washing Machines
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
551 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
