Question about Kenmore 20" 1.1 cu. ft. Pizza Maker and Microwave Oven Combo
Kenmore microwave pizza oven drawer sticks
After about 30 months of regular use, the pizza drawer stuck in the closed position. When pulling on the drawer handle the right side would budge slightly, while the left was stuck. After a few minutes of twisting and pulling it broke free. Upon inspection of the interior, the left side drawer slide has more "play" than the right (it pulls out about 1/2" further, and has some "springiness" to it, whereas the right side has a positive stop when fully open. I assume the left side drawer slide is damaged, but cannot see exactly what/where.
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave runs constantly
If it's less than a year old, it's under warranty and you should call the nearest Sears store for free repairs. Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number here: http://www3.sears.com (the 3 is correct)
Posted on May 08, 2007
  • 12 Answers
SOURCE: Kenmore microwave uneven base
It seems that when you bought the microwave the metal or plastic on the bottom of the unit is bent or warped. If I were you I would return it because yo cant really fix it
Posted on Dec 30, 2007
  • 25 Answers
SOURCE: Kenmore Microwave door adjustment
Depends on the door. It likely can be adjusted they have 2 screws on the door bracket you may have to remove the cover to see them. But it also needs to be checked with a leakage meter to make sure its not leaking.
RadioShack used to make a low cost meter not certified or anything but a good way to see if its leaking.
Posted on Jan 14, 2009
localwonder
  • 6784 Answers
SOURCE: After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Posted on Jun 19, 2009
  • 327 Answers
SOURCE: 66993 pizza oven microwave oven combo
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Posted on Jul 13, 2010
How to bake pizza in rival micro wave .??how to set it?
Unless the pizza was specifically packaged for microwave use, pizza cooking in a microwave is usually a bad idea. They don't turn out well. Although microwaves are referred to as "ovens", they really don't bake things, they boil them by heating the moisture in the product. Thus, pizza crust will not rise and get crispy unless the pizza was pre-made to be microwave reheated. Those pizzas will give instructions on how to microwave them.
Nov 06, 2015 | Rival Microwave Ovens
How to change kenmore microwave oven pizza turntable motor
check under neath if not from the inside b carefull they hold a 10.000 volt charge via a capasotr and if u touch it can kill
Feb 28, 2015 | Kenmore Microwave Ovens
Kenmore pizza microwave beeps constanly
This is not a solution, it is a clarification request, but it looks like FixYa took away that helpful option, too.
I would suggest you post a whole new help request and be sure to tell us:
1. The FULL model number from the tag in or on the microwave. A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
2. Let us know when it beeps. Is it only after cooking? While it's setting idle?
3. Next, let us know if the display has anything in it besides the normal clock time.
A good first step might be a hard reset, accomplished by unplugging the oven for a minute or two, plugging it back in, then resetting the clock.
Dec 11, 2012 | Kenmore 20" 1.1 cu. ft. Pizza Maker and...
I have a Samsung SMH9187 microwave oven that is about 9 months old. Just a few days ago, we opened the door to put something in and the fan instantly turned on. Closed the door and it stopped until we...
This problem is caused by a microswitch that is sticking in the closed position. Inspect and replace the defective microswitch in the latch assembly.
Nov 28, 2017 | Samsung SMH9187 Microwave Oven
Emmerson microwave oven and grill
mcdevito75 here, Follow the directions on the frozen pizza package, Or simply microwave at 2 minute intervals till the pizza is done or fully heated up.
Jun 22, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
If you use the microwave and forget to clear the time remaining. Or, if you just leave the food inside, the microwave will start itself in the Pizza mode. I guess it thinks the pizza needs to be reheated??...
You should have a 'clear' button on your oven.
Try to not open the door with the oven running. This causes arcing at the door safety interlock switches and they will fail.
You will know they failed when everything works but there is no "heat". No heat because the oven will think the door is open ... even though you know the door is closed.
Enjoy your new oven ... they are great. I dont know how the Mrs and I would eat if not for the mocrowave!!!
Oct 20, 2009 | Jenn-Air JMC8130DDS Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
How to make pizza in oven
buy a pizza base...its readily available in d market. put it in d microwave for 5 mins then grate some mozzarella cheese and put on top of d pizza base...den put some vegetables...like capsicum, tomato, olives, etc.. again put it in microwave for 10 mins... if needed den put again for some more time, put some ketchup on top.. n ur pizza is ready
Jun 16, 2009 | LG LMH1017 Convection Microwave Oven
Microwave oven does not heat anything
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
l;hkhtguii
Oct 13, 2008 | Magic Chef MCP13E1ST 1000 Watts Microwave...
Kenmore 20" 1.1 cu. ft. Pizza Maker and Microwave Oven Combo Logo
48 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
