Question about Sewing Machines
Stop motion knob stuck - Sewing Machines
2 Suggested Answers
  • 980 Answers
SOURCE: took stop motion knob off how do the pieces go
You should have a three pronged washer, put that on first anyway round, then put the stop motion wheel on and tighten fineger tight, tighten the small screw that should be on the stop motion wheel and tighten a bit more, if it does not tighten up take the stop motion wheel off and put the three pronged washer in a different position.
Posted on Jul 18, 2010
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Jan 31, 2014 | White Sewing White 3032
VX808/Vx809. When put pressure on foot control stop motion contro doesn't move.
I would suggest that the machine needs to be serviced to find out why it not responding the way it should.
Mar 22, 2012 | Brother Sewing Machines
Brother VX-1100 - Stop motion knob will not move, the machine hasn't been used in a while, how do you get the knob to move? Thanks Si
This sounds like there may be some oil that has turned to varnish and is therefore, seizing the stop motion knob in place. The old oil will have to be dissolved unless it has just been overly tightened. With the machine not used in some time, it should be serviced and lubed so it will work like new again.
<Ray>
Nov 05, 2010 | Sewing Machines
I turned the stop motion knob in order to wind a bobbin and the knob fell off! I have tried to put in back together but now only the knob will move not the balance wheel. As as result the clutch will not...
There should be a washer that fits over the balance wheel, if you dont put that back on the machine wont work.
Check around and see if it fell off when you removed the knob, or check to see if it is stuck inside the knob.
The washer is about 1" in diameter with a couple little tabs on it.
It will only work when installed correctly so if at first you fail just turn the ****** over!
Aug 26, 2010 | Janome L-344 Mechanical Sewing Machine
Took stop motion knob off how do the pieces go
Jul 17, 2010 | Sewing Machines
Stop motion knob won't tighten
Remove the stop motion wheel and you will see another part that is loose(looks kind of like a washer with ears on it). Reposition this on the shaft and put the stop motion wheel back on. The stop motion wheel was too loose and it allowed the washer to fall off the shaft. The screw is nice to have and it keeps the washer from falling off the shaft but it's not absolutely necessary to use the machine. Just be caredul when winding the bobbin.
sewman7
Dec 03, 2008 | Sewing Machines
Stop Motion Knob
Dear Jim,
I'm sure you have a pair of Channel lock pliers around.Place a fairly thick piece of fabric around the inner knob to keep from scratching it. Grasp it with the pliers while holding the handwheel and turn it to the left. IF you can't hold the wheel to keep it from slipping, place a screwdriver or something else under the needle set screw area, turn the wheel until the set screw is resting against the set screw and then turn the inner knob with the pliers.
sewman7
Aug 31, 2008 | Sewing Machines
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
